New blower motor
Looking to get a new blower motor for my 79 stepside. Frame off show truck. I want to get an ac delco. Couple to choose from. The main two are with ac and without ac. Ac is like $100 where non ac is about $50. I have ac but not hooked up. What is the difference? Do i need the ac fan?
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
Re: New blower motor
It’s getting cold in here.
![]() Join Date: Aug 2014
I think a/c blowers and a/c control head operate a little different. If you have a factory a/c system I would buy the correct one. Im not sure on the technical differences though
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
I wonder if it has something to do with the fact that there is no off position for non-AC trucks, at least that is how it is on my 78. The fan always runs. I would think the blower motor itself wouldn't be different. I'll look at my wiring diagrams tonight and see if I can come up with something. It could be a physical difference based on space constraints. I would go with the AC one though in any case.
LMC truck shows the same part number for both for 79 for some cases There are some differences that have to do with vent hole diameter that could be the difference. Other than that, the difference is in the resistor block which is what I would expect. Also the FAN sizes are different is some cases.
http://www.lmctruck.com/icatalog/csb/full.aspx?Page=179 |
x2
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
#7 | |
#8 | |
It is out on the duct in the engine compartment with the blower motor. Oh and the wiring diagram doesn't show anything difference for AC vs non-AC.
I think i will pull the old one off. Take it down and compare.
Have you checked Rock Auto? There are several different ACD blower motors available. The descriptions may help you. If you buy one there, remember to use their 5% discount code - google it to find the current code.
https://www.rockauto.com/en/catalog/...wer+motor,6916 |
