Old 03-10-2018, 05:01 PM   #1
akart
Re: Bilstien shock experiment $$
Originally Posted by Stephen Watson View Post
This is not how I prefer to address this but it's time.
Many people on this public forum (myself included) are really trying to help you but your continual use of measurements from incorrect positions on the truck and before a major problem was identified and corrected make it difficult to work through. We didn’t just send you 56” springs because that’s what we wanted to get rid of. The application info and physical measurements you gave us would require a 56” rear spring. Continually stating that we sent you the wrong springs and would not stand behind them is a lie. Please do not do this anymore, especially in a public forum. You stated numerous times on this forum that you have a K30 frame. K30s come with 56” springs. You told us numerous times you had a K30 frame. Knowing you had a mix of parts we had you measure the springs just to be sure and received a measurement of 54” which supports a flat length of 56”. The fault for receiving springs that did not fit your truck does not lie with Offroad Design. Luckily this was a relatively simple problem to solve given the cost of shipping springs from and to your location.
Now if we can move forward by checking proper current measurements we can see if there is still a problem with ride height. I understand it could be a while before the truck melts out and that’s fine. We’re not going anywhere. Keep it nice until then.
It was established early on in the string of email to your associtate Chris that I had a K20 (3rd email 6/8/16).I have forwarded this string of emails to you, and I also asked if there was any further information that was required. I will furnish current measurements as soon as I can. Thank you very much
akart is offline   Reply With Quote
Old 03-10-2018, 06:28 PM   #2
akart
I think I may have this figured out. I have a K20 and ORD sent me springs for a heavier K30.That would explain the excess height in the back as it won't settle and the stuff ride. What do you think??? Thank you.
