Old 03-11-2018, 01:42 AM   #1
69GMCCustom
69GMCCustom's Avatar
Guess what this hole was for
Been lurking for years, started a truck 69 gmc longbed and had to sell it, and finally got a new one 70 c10.
I keep wanting to start a build log, just haven't gotten around to it. I will.
As many of you have seen numerous "modifications" over the years, I wanted to ask your help.
Can anyone identify what this hole was created for? That's between the driver's side door and the instrument cluster.
"I'm rooting for you, and remember, were all in this together." ~ RED GREEN
1970 Chevy Custom.
69GMCCustom is offline   Reply With Quote
Old 03-11-2018, 01:55 AM   #2
Richard2112
Richard2112's Avatar
Re: Guess what this hole was for
I have a similar hole or holes in the same location on my 70 c30. Maybe it was a trend back then to lock a chimpanzee in the cab with a cordless drill.
Richard2112 is offline   Reply With Quote
Old 03-11-2018, 02:08 AM   #3
69GMCCustom
I agree. This one had been dropped, without changing the original ball joints or shocks. Lol. It does seem to be a 2 owner vehicle tho.
1970 Chevy Custom.
Old 03-11-2018, 02:12 AM   #4
stsalvage
Scrapper 1
stsalvage's Avatar
could it had been for a spot light.If you have a bigger pic pf where it is it would help
stsalvage is offline   Reply With Quote
Old 03-11-2018, 02:35 AM   #5
69GMCCustom
Here is a larger area of the hole.
The corresponding hole on the outside cowl. Note the amazing handiwork.
And the strange grommet I found on the roof, filled with Bondo as well. I assume this corresponds to the cb radio mount holes under the lip of the dash.
1970 Chevy Custom.
Old 03-11-2018, 02:43 AM   #6
Richard2112
My C30 had emergency lights mounted on the roof at one time so the were several roof holes also.
Old 03-11-2018, 02:50 AM   #7
69GMCCustom
This one only has one grommet, center of the roof. But it came power steering, brakes, tinted windows, a/c , heavy duty suspension, so a spotlight wouldn't surprise me.
1970 Chevy Custom.
Old 03-11-2018, 10:44 AM   #8
clay68c10
clay68c10's Avatar
That dash to pillar hole was definitely a spot light.
Maybe the roof was also. Mine had a roof mounted spot when I bought it back in 89. Get that hole sealed up or you will end up needing a new roof/cab. Ask me how I know...
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-11-2018, 11:17 AM   #9
69GMCCustom
Clay68c10- Never seen a roof mounted spotlight. But, I wish they were both still there, guess it's just two more things to keep a look out for at the junkyard.
1970 Chevy Custom.
Old 03-11-2018, 12:50 PM   #10
weq92f
weq92f's Avatar
Maybe it was some type of rescue or emergency truck in the past?
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 03-11-2018, 01:44 PM   #11
69GMCCustom
@ klb. Who knows?
There is an inner hole to match the roof hole as well. Time to collect pictures, and start searching for parts. If I can find em, I'll put them back on.
Thanks for your help!
1970 Chevy Custom.
Old 03-11-2018, 02:03 PM   #12
BugzC10
BugzC10's Avatar
That is my first guess also....
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 03-11-2018, 03:20 PM   #13
weq92f
weq92f's Avatar
Originally Posted by 69GMCCustom View Post
@ klb. Who knows?
Whatever was mounted north of the original rear view mirror mount was probably the "controller" for whatever was mounted in the center of the roof panel. I'm guessing it was a strobe of some sort or other type of light bar. Check around the edges of the roof inside the door jambs for some mounting holes or marks where something may have been wedged there or for mounting holes.
It could also have been an antenna maybe, although that seems like an extreme measure to cut a hole for an antenna!
-klb
Old 03-11-2018, 05:16 PM   #14
69GMCCustom
There are no real marks on the door jamb, but I would think a roof rack type accessory would not need a hole drilled as well. But your right, that would be overkill for an antenna. It seems no one takes pictures of the interior roof of the cab.
-klb
1970 Chevy Custom.
Old 03-11-2018, 06:17 PM   #15
weq92f
weq92f's Avatar
It could have also been a siren or megaphone.
Checkout this thread of ambulances:
http://67-72chevytrucks.com/vboard/s...d.php?t=403359
-klb
Old 03-11-2018, 06:45 PM   #16
weq92f
weq92f's Avatar
Couple more threads with some interesting bits of info:
http://67-72chevytrucks.com/vboard/s...=siren+install
http://67-72chevytrucks.com/vboard/s...ghlight=rescue
-klb
