Re: The Definitive 67-72 Seat Swap Guide Thread ....
Here is the progress I've made on my '69 C10 Stepside. Seats / console are from a 2011 Chevy crew cab in titanium leather. Self designed door panels and dash pad have been made to match by Cy-Fair Upholstery and Glass. Center jump seat cushion is a JL Audio Stealthbox also covered to match.
Installation was straightforward. Drilled (8) ~5/8" holes, used 3" diameter 1/4" thick cadmium washers under cab floor, with lock washers, stainless steel industrial grade bolts and cupped washers on the seat track provisions. I'm 6'-4" and the seats are very comfortable. They are 8-way power so they go forward, back, up, down, tilt bottom cushion front or back, etc. I would not install these generation seats without power as you will not have the height and bottom tilt adjustment without power. They also have manual lumbar. A tilt column is a must for entry and egress. Power is achieved with a 12V power and ground, that's all that is needed. I also ran a dedicated 12V and ground for the factory 12V power supply in the console.
1969 C10 Stepside (PERCY - tribute to CDE) 1996 Chevrolet Tahoe 2-door / 2WD LS5.3/4A (ROBYN) 1998 GMC SLE Regular Cab Short Bed Fleetside 4.3/4A (LUCY) (driver) 2000 JEEP Cherokee Sport XJ 4x4 4.0/4A (RUBY, son #2) 2013 VW GTI Driver's Edition 1.8T/6A (GRAU GEIST, son #1) 2016 BMW X5 xDrive50i MSport 4.4L N63/8A (SCHNEEWITTCHEN) |
| Bookmarks |
