03-12-2018, 10:52 PM | #1 |
Stripped out heater box
I was replacing my blower motor this weekend and the holes in the box are stripped out. I squirted in some fiber glass resin and drilled out and it did not take. Any thoughts out there? Should i drill out bigger and jam some fibers in the hole? Seemed like the resin did not adhere to the box. I have a 79 c10. Fiberglass box.
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
03-12-2018, 11:11 PM | #2 |
Re: Stripped out heater box
What about those clip on nuts or using butterfly bolts
03-13-2018, 03:32 AM | #3 |
I would clean out the resin you put on there, and chop up some fiberglass mat and mix it with some epoxy, then fill and re-drill the holes after it sets up good.
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
03-13-2018, 07:24 AM | #4 |
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
03-13-2018, 10:31 AM | #5 |
Those clips could work if i modified the box. The box is flat. But each screw hole has a thicker portion added to give the screw more to bite. I would have to cut these off. An option of my glass fiber option does not work
03-13-2018, 03:36 PM | #6 |
How about a rivet nut insert?
https://www.amazon.com/dp/B072QWZPWK Or possibly a threaded nut insert? You can tighten the insert down, clamping it onto the heater box. Add in some loctite or epoxy and it should never come out while backing out a screw. https://www.amazon.com/dp/B00YJDZ2JS |
03-13-2018, 07:01 PM | #7 |
rotate it slightly and make new holes.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
03-13-2018, 08:09 PM | #8 |
Good ideas. Some things to think about. Thanks guys
