Old 03-04-2018, 07:31 PM   #1
OutlAw_8
Tires
What's the biggest tire guys are able to use on stock rally wheels and without chopping the truck bed? I'd like bigger back tires and stock up front . Thanks in advance
OutlAw_8 is offline   Reply With Quote
Old 03-04-2018, 08:24 PM   #2
RodnRudy
RodnRudy's Avatar
Re: Tires
I'm running 275/60's on an 8" rally. That's with a '71 5 lug rear end. The fit is right on the money
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 03-04-2018, 10:35 PM   #3
OutlAw_8
Re: Tires
That's a great look on the truck, nice truck man! Thanks for the info
Old 03-14-2018, 12:03 AM   #4
OutlAw_8
Re: Tires
What brand of tires are you Running? And what size front tires do you have?
Old 03-14-2018, 01:49 AM   #5
3757chevy
3757chevy's Avatar
Re: Tires
BFG 285/70-15 on rear 245/60-15 front for my step side, and my 71 longbed.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 03-14-2018, 07:52 AM   #6
OregonNed
OregonNed's Avatar
Re: Tires
I’m running the same size as RodnRudy
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 03-14-2018, 12:15 PM   #7
RodnRudy
RodnRudy's Avatar
Re: Tires
The tires are Cooper Cobras, they were $300 cheaper than BF Goodrichs.
The front tires are 225/70 15. Fronts are mounted on 6 1/2" rallys.
Thanks for the compliment on my truck!
Phil
Old 03-14-2018, 12:40 PM   #8
197D_C10
197D_C10's Avatar
Re: Tires
I'm running 8" rallys with BFG 275/60/15 on all for corners.
197D_C10 is offline   Reply With Quote
Old 03-14-2018, 02:30 PM   #9
gearheadperkins
gearheadperkins's Avatar
Re: Tires
awesome truck and stance... how much of a drop if you done mind me asking.. this is the look I want for my 72
1972 Chevy C10 400sbc 4sp
Matthew 4:19
And he saith unto them, Follow me, and I will make you fishers of men.
gearheadperkins is offline   Reply With Quote
Old 03-14-2018, 03:25 PM   #10
knomadd
knomadd's Avatar
Re: Tires
I'm not running rally's, but if you find one that would fit a 295 width tire, it should fit without chopping anything up. You'll just need the right backspacing to get it to fit. I'm running 295s on a 10" wide wheel with 5.5" backspacing on a stock 71 width rear.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-14-2018, 03:28 PM   #11
197D_C10
197D_C10's Avatar
Re: Tires
Thanks. The front has a 3 1/2 in drop (2 1/2" drop spindle and 1" drop coil) from Early Classic Enterprises. The back has about a 5" drop on it. Its a leafspring rear and was done by one of the previous owner so its hard to tell for sure. I added the front drop kit after i bought it to convert from drum to disc. My buddy's 72 has the 3 1/2" front 5" rear drop from Early Classics and his is a coil spring rear setup and they sit pretty close to the same height which is why I stated I have a 5" drop on mine.
Old 03-14-2018, 06:14 PM   #12
RodnRudy
RodnRudy's Avatar
Re: Tires
I've got 2 1/2" drop spindles and 3" drop springs in the front and 5" drop springs and 2" lowering blocks in the rear. That makes it a 5 1/2, 7" lowering overall. I do have the c notch in the rear frame. Thanks for the compliment!
Phil
Old 03-14-2018, 06:29 PM   #13
197D_C10
197D_C10's Avatar
Re: Tires
I guess I should pay attention before i quote a response intended for someone else. My bad....
Old 03-14-2018, 06:41 PM   #14
RodnRudy
RodnRudy's Avatar
Re: Tires
Don't feel bad, I just figured out how to do the quote thing yesterday! LOL
Phil
Old 05-08-2018, 11:03 PM   #15
mikelom
Re: Tires
I currently run 275/60/15 cooper tires and they look sharp. Will get a set of BFG soon.
mikelom is offline   Reply With Quote
