Old 03-14-2018, 10:03 PM   #1
Jeffh
Windshield Gasket
Are Steele Rubber Products windshield gaskets worth the $112 compared to all the other repop suppliers asking $30? I guess I don't mind spending the extra is if REALLY is worth it.....
Jeffh is offline   Reply With Quote
Old 03-15-2018, 01:09 AM   #2
LVPhotos
LVPhotos's Avatar
Re: Windshield Gasket
Precision Rubber has both standard and for metal trim $75
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-15-2018, 03:25 AM   #3
sirJim
I just replaced my precision ( which I couldent get to fit ) With Steele rubber. 2 hours and the help of a couple friends rubbber instalation liquid and lots of calm ease it in it fits perfect.
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 03-15-2018, 07:55 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
$60 for Precision windshield seal - https://www.prp.com/product/detail/1...ickup&type=All
$90 for Steele windshield seal - https://www.steelerubber.com/windshi...ket-70-1702-50
Having said that I haven't gotten that far yet.
Old 03-15-2018, 01:02 PM   #5
Heater63
Heater63's Avatar
I am very dissapointed with the fit of my Precision gasket which was professionlly installed last year. I am considering trying a Steele. Will be following you string, please update us with your experience.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 03-15-2018, 01:37 PM   #6
61K10
61K10's Avatar
My precision fit perfect (no trim one) that was a few yrs a go. quality gone down?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-15-2018, 03:36 PM   #7
jayoldschool
Moderator
A couple of years ago, when it was gasket time for me, everyone here said Precision was the best...
jayoldschool is online now   Reply With Quote
Old 03-15-2018, 04:01 PM   #8
gmcdeadhead
gmcdeadhead's Avatar
i did mine a few years back, used the steele gasket with trim, i put it around the windshield and put the string in the grove , then taped the gasket to the glass to hold it in position for a few days so it would form to the windshield, i went to harbor freight and bought two of those glass suction cups, they work great for the amount of time your going to use them, spray plenty of soapy water on the gasket , that is what i used , have some one on the outside pushing in while you use the suction cups and pull on the string , only takes about an hour, use plenty of soapy water , hope this helps
gmcdeadhead is offline   Reply With Quote
Old 03-15-2018, 04:24 PM   #9
forestb
forestb's Avatar
I got mine from steel and it took the window guy forever to install it and the trim doesn't fit properly. I don't know if it is because it was from steel or if that trim is just hard to install.
forestb is offline   Reply With Quote
Old 03-15-2018, 06:26 PM   #10
jayoldschool
Moderator
Did your window guy know that the trim goes on the gasket before the window goes in?
Old 03-15-2018, 06:45 PM   #11
The Rocknrod
Moderator
Very much like the video shows how to do it. - https://youtu.be/zA8sX1KR6J0
Old 03-15-2018, 07:15 PM   #12
forestb
forestb's Avatar
I don't know I was not there. Mine is a 62 and that might make it more difficult.
Old 03-16-2018, 01:13 PM   #13
61K10
61K10's Avatar
Years ago we were restoring a 57 olds conv. first one from steel was too small the second one had a loop in it (we called it something else back then) they screwed up when they put the ends together. Window installer got one from his shop which fit. Best bet is get one and put it on your windshield and see if it fits. If not send it back.
1961 chevy K10
Old 03-17-2018, 11:58 PM   #14
luvbowties
luvbowties's Avatar
Thumbs up Re: Windshield Gasket
It may surprise you to see how much the 'come to your shop guys' charge for parts and labor to install it. [And breakage is on their dime.] At least, that's the way it is around here, in Upstate SC. Hope you are pleasantly surprised!
Sam
luvbowties is offline   Reply With Quote
Old 03-18-2018, 09:29 AM   #15
Macdaddy1
Was reading a thread on window install and evidently silicone is a no no for the paint but guys have been using RuGlyde on the rubber before install to help with lubrication. Seems like a good product and inexpensive.
Macdaddy1 is offline   Reply With Quote
Old 03-18-2018, 11:39 AM   #16
The Rocknrod
Moderator
Correct me if I'm wrong but I thought silicon was bad for new painting projects, not cured paint.
Old 03-18-2018, 06:30 PM   #17
63burban
Chevy addict
Used several Precision gaskets on 60-66 trucks with glass cleaner and or soap and water and all went good. Probably 60-63 takes the longest at about an hour
63burban is offline   Reply With Quote
Old 03-30-2018, 03:47 PM   #18
Precision Parts
Tech Help
Precision Parts's Avatar
This is always what we recommend. These are good lubricants that don't hurt your paint and will dissipate in a short amount of time which is what you want.
In this video we show you how to install this seal correctly. This was installed on Mike Losh's 65 (boosted bertha) that was in our booth at Sema in 2015.
-Derek
PRECISION
Updates
Subscribe --->Installation Videos
Follow ------->Instagram
Like---------->Facebook
Precision Parts is offline   Reply With Quote
