Old 03-11-2018, 11:40 PM   #1
putnam00
Metal in oil
I have changed my oil twice once in sept the oil plug was covered in super fine shavings, I know some is normal. When I changed it last weekend the oil plug again was covered in shavings and you could even see it in the oil. I know something is bad, could it be the oil pump? I have run about 20 psi when its cold and it will go past 40 it high rpms, but around valentines day i actually had the display say low oil pressure and ran really low, I stopped checked the oil and it was only 1/4 of a quart low. i restarted it and it was showing more pressure. it has just over 235,000 miles and runs good i have a picture of the oil shown
putnam00 is offline   Reply With Quote
Old 03-12-2018, 07:39 AM   #2
homemade87
Re: Metal in oil
Most likely a main or rod bearing giving up . You cant keep driving it and expect it to get better . That metal is traveling the motor . Good chance it will leave you somewhere so now is the time to plan .
Either take it out and see what is wrong and repair ( engine will have to come completely apart to clear the metal ) or get a pull out to replace it with .
Either way dont ignore it . Do your planning while you still have time .
homemade87 is offline   Reply With Quote
Old 03-12-2018, 08:13 PM   #3
Tom
driving is in my blood
Tom's Avatar
Re: Metal in oil
40psi of oil pressure at 5000rpm is at least 10psi too low.
Throw some 20-50 in while you save up for rebuild. Might work, might blow up just as quick. Its a gamble if you dont take apart to diag.
Old 03-15-2018, 08:38 PM   #4
putnam00
Re: Metal in oil
Yeah at times when I pass someone the oil pressure will hit 50psi and other times be lucky to hit 40psi
Old 04-22-2018, 09:51 PM   #5
7 Devils
7 Devils's Avatar
Re: Metal in oil
Attachment 1762565
At this point yes probably well on the way to smoked bearings. For future reference, this is a common problem with the LS based truck motors and the solution is a $4 dollar O-ring.
So the oil pickup tube has an O-ring that will develop cracks over time. When this happens the oil becomes aerated and begins losing oil pressure intermittently.
There are a couple tell tale signs. PM for more info.
Dan
Forgive my typos, big fingers and little Android digital keyboard....what a mess
06 GMC Sierra crew cab Z71 DD leveling kit, 34's, bumper, LED lighting. Still doing stuff to it.
67 El Camino Custom 300 Deluxe. In progress.
55 GMC 371 2 1/2 ton. Upcoming project.
7 Devils is offline   Reply With Quote
