Old 03-15-2018, 06:45 PM   #1
67GMC351E
67 351e
just bought a 67 gmc with 351e v6, had a blowen head gasket, #4 cyl, blowen out towards the push rod gallery.i couldnot find a head gasket for it so i went to cometic gasket and got solid copper gasket, never installed a solid copper gasket before so i spayed on copper coat and installed them after i had the heads resurfaced and valve job done ,filled with coolant run engine found all it wanted to do is push the coolent out the rad overflow guess i did somthing wrong any sugestions?
67GMC351E is offline   Reply With Quote
Old 03-15-2018, 06:52 PM   #2
harpo231
harpo231's Avatar
Re: 67 351e
sounds like air may be trapped in jackets
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-15-2018, 08:49 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 67 351e
Even though you had the head surfaced, you'd have to also deck the block to get a copper gasket to get a good compression seal, in my experience. It is also possible that the block is cracked. You're getting a compression leak into the cooling system, is my take. What to do? That depends on how deep your pockets are. Maybe someone knows an economical solution for you.
~Steven
Simi Valley, CA
