Old 03-16-2018, 05:19 PM   #1
paul blair
Poly fuel tank???
This tank is made in the USA according to the description...I need a new fuel tank and wondering if any of you have installed one of these...any problems with these POLY TANKS...fit issues...Don't see made in the USA much any more!
paul blair is offline   Reply With Quote
Old 03-16-2018, 05:26 PM   #2
Problems
Problems's Avatar
Re: Poly fuel tank???
who is that from and how big is it? New vehicles come with poly tanks I wouldn't be concerned. Actually I am asking who its from because I would be interested in one myself. My truck has an aluminum cell but it's only 13 gallons and doesn't have an internal pump.
Problems is offline   Reply With Quote
Old 03-16-2018, 05:31 PM   #3
Custom 68
Custom 68's Avatar
The one I ran looked very similar and didn't have any issues. I had used mine for several years with an external pump for my efi. I was able to swap to an aluminum tank with the pump internal.
My tank fit fine however it did hang down so it was visible, there was no safety concerns but I didn't like the way it looked.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-16-2018, 05:35 PM   #4
paul blair
GMCPAULS Has Steel and POLY 21 gal
Old 03-16-2018, 05:39 PM   #5
paul blair
Thanks Dave
Old 03-16-2018, 06:21 PM   #6
Rufas
Rufas's Avatar
I just sold the exact tank yesterday. I purchased it from Brothers about 20 years ago. I installed it, but never used it. You will need to modify a sheet metal bed support by cutting about 1/2 out of it so that the tank can sit flush with the frame.
The reason for selling is I went fuel injection and slammed the truck. I was a little concerned the the ground clearance with the poly tank.
BTW - I gave it away for $100
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 03-16-2018, 07:42 PM   #7
Jrainman
Jrainman's Avatar
I bet they are made by GTD ( Gas tank depot )they are out of Florida they are plastic gas makers, and all there tanks are made in the USA
Jrainman is offline   Reply With Quote
Old 03-16-2018, 09:06 PM   #8
paul blair
Thanks RUFAS and JRAINMAN the information
Old 03-16-2018, 09:57 PM   #9
gottattooz
gottattooz's Avatar
http://67-72chevytrucks.com/vboard/s...=468341&page=4
Post #80 and 81 has pictures of the mods i did to the bed to make my poly tank sit flush with the frame rails.
-Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 03-17-2018, 05:52 AM   #10
paul blair
-Josh
Thank You Josh, This helps a lot...
