Old 03-03-2018, 01:57 PM   #1
Jferrante
Jferrante's Avatar
Patch Panel Help
Need some help - does anyone sell a patch panel to replace this part of the cab right where the floor meets the firewall on driver and passenger side?
Jferrante is offline   Reply With Quote
Old 03-03-2018, 02:46 PM   #2
Rob 61 apache
Re: Patch Panel Help
I had the same issue with my apache,I made a piece from scratch for both sides,I welded the drivers side already but I didn’t weld passenger side yet,if I go back to shop I’ll take some pictures of the piece I made
Rob 61 apache is offline   Reply With Quote
Old 03-03-2018, 02:49 PM   #3
Jferrante
Jferrante's Avatar
Thanks thats what I was thinking as well...what gauge sheet metal did you use?
Old 03-03-2018, 03:05 PM   #4
Rob 61 apache
If I remember correctly 18 guage
Old 03-03-2018, 05:00 PM   #5
Pinchecharlie
Yeah mine's even worse. Was looking today at ecklers trucks. They have any and all patch panels available. So does lmc and others. Just Google c10 patch panels if you care. They are often cheaper to buy than build if you don't have the metal around and then fabricating them takes time. Unless it's a custom piece or super easy I just buy them now. For example you can buy an entire floor for our trucks for 550 +a lot for shipping. A local shop just did a 55 truck and I watched them do a new roof, new floor , rockers and fire wall So basically a new cab. Took them 3 day. Pretty wide aray of sizes too. You can go just do a piece to the. Firewall bend and or drive seat or from firewall front to back with different pieces. Check it out. Lots of fitting I am sure but a easy start. Ecklers are all 16 or 14 gauge. Good luck. Mine needs all cab supports , inner and outer rockers and both footwell. I am skinning doors to (95 bucks cheap) should have bought a better cab! Just spent 2k on new bedsides fenders and wood too! Ugh! Oh Well it's fun!
Pinchecharlie is offline   Reply With Quote
Old 03-03-2018, 05:24 PM   #6
Jferrante
Jferrante's Avatar
Ecklers and LMC dont have it unless I am missing something on their sites. I also looked at bowtie and others. Think I will just make it.
Old 03-03-2018, 08:30 PM   #7
padresag
read this link
http://67-72chevytrucks.com/vboard/s...d.php?t=708458
ron
padresag is offline   Reply With Quote
Old 03-03-2018, 08:40 PM   #8
Rob 61 apache
Here’s a few pictures of what I did,the pictures are taken from outside the cab(my cab is off the frame)I decided to take a little more rust out that’s why there’s 2 pieces,I bent the one end in my brake and the other side with an anvil and body hammer,hope this helps
Old 03-03-2018, 08:52 PM   #9
Pinchecharlie
Oh shoot sorry about that! Should have looked first
Old 03-03-2018, 09:53 PM   #10
Jferrante
Jferrante's Avatar
Originally Posted by padresag View Post
looks like that webpage is no good once you try to go to the chevy section
Old 03-03-2018, 10:41 PM   #11
padresag
perhaps they are some page changing. you can always call them. it was working a while back and they did look good
ron
Old 03-05-2018, 10:09 PM   #12
jdl71
jdl71's Avatar
Or any other section. I just tried as well. I was really hoping I'd be able to see what they have, no one seems to make any floor sections that go far enough up towards the firewall.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 03-05-2018, 10:33 PM   #13
Jferrante
Jferrante's Avatar
Yea - its a hidden area on the cab and relatively flat so I am going to just patch with some sheet metal and report back.
Old 03-05-2018, 11:20 PM   #14
padresag
home page is there so it is working. perhaps they have a problem, as I have already said. you can always phone them as their nbr is there
ron
Old 03-06-2018, 07:51 AM   #15
PGSigns
PGSigns's Avatar
Jeff most of the inner rocker patch panels (looks like you need) will go up about 4 inches up and that will get most of what you need. The foot well patch will fix where it meets the side. For the little bits that are left you can use the drop from the other patch panels.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-06-2018, 09:27 AM   #16
Jferrante
Jferrante's Avatar
I have the side kick panels, not an issue, looking for the floor piece but I will just use sheet metal
Old 03-06-2018, 09:54 AM   #17
Rob 61 apache
I found a picture of my drivers side before I welded it(FYI the two holes are where the dimmer switch is)I did exactly like jimmy explained,new kicks,new floor,I also did the cab mounts,the metal around the dimmer switch was still good so I didn’t need to go that far up,hope this helps a bit
Old 03-06-2018, 01:12 PM   #18
padresag
for the negative ones i did email them and the links are being repaired
ron
Old 03-16-2018, 08:40 PM   #19
jdl71
jdl71's Avatar
ron
Thank you. I know we could call and ask for a catalog, etc. but the internet has spoiled us. Now we want to look at pictures of everything from the comfort of our la-z-boy.
Psalm 23
64 C10
66 K20
Old 03-16-2018, 08:49 PM   #20
padresag
there is another word for it.
here is the repaired link and 60-66 is on page 2 and 3 for those that need assistance
http://directsheetmetal.com/Store/in...=index&cPath=2
ron
Old 03-16-2018, 08:58 PM   #21
Jferrante
Jferrante's Avatar
Thank you for following up. This is the left hand "toe board" and must be upside down. But for 60 bucks may be worth a shot.
EDIT; 40 BUCKS TO SHIP - NO CHANCE
