#26 |
![]() ![]() Join Date: May 2015
Re: Project 66: LS and Frame on the Ground
sweet looking old 66.....did you replace the headbolts? those are one time use torque to yield....
#27 |
#28 |
That motor cleaned up nicely, paint look great. Can't wait to get mine looking like that!!
#29 |
#30 |
Got some Por-15 on the front part of the frame..most of the rear comes out with the choppin block kit. Will paint once it is all together.
#31 |
CB kit came yesterday in a bunch of boxes. I didn't have time last night to go through it so tonight after work I started the unwrapping and began on the front end.
The dropmember uses the factory holes but the bolts are a tad larger so you need to run a step drill bit and you are good to go. From there you add the inner frame support, upper bag mount and engine mounts. The engine mounts will go on the motor before dropping it in to ease that process. Once the drop member is in its just a process of installing your ball joints and bushings and then installing them on the drop member. Really not too much. The hardest part is making sure you have the parts on the correct side of the truck. I still need to install the lower ball joints and the shock relocation brackets and then I am moving on to the rear. Christmas in Feb ![]() Dropmember and inner frame supports in ![]() Closer look at inner frame mounts ![]() ![]() Motor mounts in their place ![]() Upper bag and control arm mount ![]() and most of it in ![]() until tomorrow ![]() and another present for myself... ![]() |
#32 |
60-66 Nut
Very nice!
#33 |
![]() Join Date: Dec 2006
Looking good! Makes me miss my choppin block front crossmember
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#34 |
Frame cut and cross member out - took a few cut off wheels and created a ton of dust but we are almost ready for final mockup, paint and assembly of the frame. Weather is ****ty but hoping its dry this weekend so I can get a bunch of these parts painted.
If anyone needs a crossmember let me know ![]() ![]() |
#35 |
Nice build. Looking forward to more progress!
#36 |
#37 |
#38 |
some good looking parts you got.....nice welder to...
#39 | |
#40 | |
Today was another busy day. I got most of the items a brief coat of paint yesterday so today's goal was to get the puzzle together. I am going to have to clean up some of the paint at some point but it looks fine for now. Nothing real hard here just a lot of drilling. Next up is welding the trailing arm brackets to the rear axle and then I plan on getting the wheels back on and engine back in the frame ![]() ![]() ![]() |
#41 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
You got me watchin' closely!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
#42 |
Nothing dramatic has changed we got a lot of snow and I lost power for 2 days and I am traveling for work so I didnt get much work done this past weekend. Regardless I am making slow and steady progress.
I got the 4 link brackets welded to the rear axles which was a nice accomplishment. It is an awkward welding angle for someone new to the craft but I got it done. Added the rear bags as well. Up front the holes for the ball joints in the spindles werent wide enough so I had to drill them out to the right sizing without over enlarging the hole. I then got the shocks mounted, steering rack in and my front wheels mounted up as well as my airbags. Next up is running some air lines and my trans mounts and hopefully getting the air all powered up and ready for the engine. ![]() |
#43 |
Tackled a few more odds and ends today including mounting the air tank and putting the motor in to check how it all sits. It isn't laying low as it can in the front so I am ordering an F Body Oil Pan kit and hoping that does it.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Jferrante; 03-17-2018 at 10:45 AM. |
#44 |
Looks like some great progress. Are you doing a one piece drive shaft?
#45 |
#46 |
You notching out the back of the cab? A one piece shaft will hit the back of the cab before laying out.
#47 |
#48 |
Nice build so far!
#49 |
#50 |
Always a bummer seeing swb frames get cut for choppin block rear kits. You should have bought a longbed frame for cheap, and sold the swb frame and recouped $5-800.
