Old 01-06-2016, 04:23 PM   #1
hkopp
Speedometer cable Length for 4x4's (and others). :)
After searching the forums and coming up empty on how long the 60-66+ 4x4 speedometer cable was I finally braved the snow and removed mine (my warm shop is full right now...grrr). Its a 1960 K10 and it is the 120" one. There are several available for our trucks, including a 63", an 83", and a 120".
Here are the part numbers for (hopefully) someones future reference.
Oreilley's and Autozone can get them via special order, as well as Summit and Jegs.
63" - ATP Y-804
83" - ATP Y-803
120" - ATP Y-863
NAPA also carries them in their Balkamp line but they are $10-$15 more and a few are a little longer than the oem.
63" - BK 6151604
87" - BK 6151606
100" - BK 6151607
120" - BK 6151616
I found a cross reference for the 120" cable in a Pioneer brand, which O'Reilly's could get from their warehouse overnight rather than the 4-5 days on a special order. It is Pioneer CA-3038. Not sure on the other part numbers thru Pioneer however. I bought this one for my truck and is fit perfect.
Hope this helps
hkopp is offline   Reply With Quote
Old 01-06-2016, 06:35 PM   #2
hkopp
Re: Speedometer cable Length for 4x4's (and others). :)
I found another Pioneer number, the CA-3004 crosses to the ATP Y-803 - the 83" cable.
Old 01-06-2016, 08:25 PM   #3
60-66
60-66's Avatar
1536478 is the GM part number for 1960 4x4 120 inches.
https://67-72chevytrucks.com/vboard/...1966+gmc+panel
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 03-17-2018, 03:35 PM   #4
66K10383
66K10383's Avatar
I'm not sure of the difference between a 1960 and a 1966 k10 truck,however I do know the Speedo cable from my truck is 144" long.
The longest cable I can find is 120" has anybody ran into this before or know where to find the proper length cable?
Thankyou.
66K10383 is offline   Reply With Quote
Old 03-18-2018, 01:36 PM   #5
66K10383
66K10383's Avatar
I ended up ordering a 140" cable for a 60s Corvair, lets hope it works well.
Old 03-28-2018, 09:35 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Amazon also has
63" - ATP Y-804
83" - ATP Y-803
120" - ATP Y-863
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-30-2021, 11:33 PM   #7
drumyn61
How did it work out.
drumyn61 is offline   Reply With Quote
4x4, cable, k10, length, speedometer
