04-08-2015, 12:48 PM | #26 |
Re: steering wheel shortening
search 67-72chevytrucks.com at the topf the screen for "Don Smith Original steering wheel, steering wheel down size" it has some good info.
04-08-2015, 01:14 PM | #27 |
I reduced the size of my '68 wheel down from 17-inches to around 15 a few years back and covered the process in Custom Classic Trucks. Used the aforementioned Eastwood kit. It's time consuming but I'm really happy with the result as it looks factory and isn't so awkward to steer now. You can read the whole story here for free!
04-08-2015, 08:00 PM | #28 | |
"Now all I need is a shop to go with my shop vac!" |
04-14-2015, 02:34 AM | #29 |
Progress report & pics. I did not get the mold completed yet & just started applying the epoxy on this steering wheel. Waiting for cure time, then it's time for lots of sanding & apply some bondo to fill any low spots, then 3 primer coats & then 3 coats of paint & clear coat. The lighting gives it an illusion of weird shapes or angles on the spoke(s), once it's finished & painted it wont be noticeable.
04-16-2015, 11:54 PM | #30 |
I finally got around to sanding the PC-7 epoxy. I let it set up real good for about 3 days. It's looking better than I expected but still needs alot of work to be near perfect.
04-17-2015, 10:48 AM | #31 |
tex dont forget i got a good doner for you to work on too. i gotta see about shipping it to you
lookin good too Rmanson. i remember reading that link a while back. i bet i still have the issue. its too bad that mag got dicsontinued
1967custom |
04-17-2015, 06:01 PM | #32 |
Is it the pictures, or is that wheel more oblong shaped?
04-17-2015, 06:35 PM | #33 |
I'm sure it's the pics because I had to rotate them (from landscape to portrait) & resize them after taking pics of the wheel with my iPhone. You had me scared thinking something was wrong, because I built it in a jig & that I know for a fact that it is perfectly symmetrical.
04-29-2015, 10:20 PM | #34 |
I'm finally getting somewhere with this & I am happy with the results! Time to wet sand & then apply one more coat of black. Don't be fooled by the contour & reflection in the last pic, it is not crooked on the bottom Y spoke. You can see that is isn't in the first pic. Have a blessed day!
04-30-2015, 03:07 AM | #35 |
Old member
Looking good man! Nice clean job.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-30-2015, 09:04 AM | #36 |
Would love the same for my truck but I'm not a welder, bodyman or painter.
Will definitely give it some thought. Thanks for sharing the process.
General Contrucktor |
04-30-2015, 04:02 PM | #37 |
Thanks man! It's been a labor of love. I know it's not perfect (to my higher standards of quality of work) but now I know NOT what to do on the next one...lol
04-30-2015, 05:09 PM | #38 |
04-30-2015, 07:40 PM | #39 |
Excellent analogy! But unfortunately, I've got do at least do 5 more, guys are waiting patiently for theirs. All work & no play could make Jake a rich man! lol
04-30-2015, 07:49 PM | #40 |
Better pics I hope, in the sun & in the shade. The orangeist color or red in the last pic is a reflection, not burn thru.
09-22-2016, 06:55 PM | #41 |
looks great!!! going to do this!! any photos of the resized wheel installed?
09-22-2016, 07:21 PM | #42 |
Old member
Any updates with photos would be great.
03-18-2018, 11:45 AM | #43 |
That is amazing! Nice job
03-18-2018, 02:19 PM | #44 |
What’s a good size for the wheel? Does a 14” look stupid small?
