Old 10-05-2017, 12:56 PM   #351
Scott2
Re: Mike's 50
Originally Posted by MIKESAD50 View Post
Scott2
It still runs up to 190-200ish depending on how I drive and also most of the driving I do is stop and go commute traffic.
I figure it would be the same aprox. as coolant temp if run thru the radiator cooler since coolant temp runs in the 200-205 range while in traffic.
Not sure if I will move it yet or not. I think if I wrap the exhaust that might help some also.
over 1325 miles and only issue so far was running out of gas once, and also had a failure of throttle system yesterday and had no pedal response, cleared throttle position sensor code and running fine again so far.
Settling on the right alittle more than right side so I will swap shocks left to right
I think I'm about 4 months out in getting my truck running so I will be going through many of the same issues I'm sure!
Regarding the trans cooler - I had good conversations with both my trans builder (mine is a stock rebuilt 4l80e behind a stock 6.0 LS-based truck motor) and the technical guys at Derale. The trans guy strongly recommended I use an external cooler and also run through the radiator. He suggested a cooler rated at 20k GVWR or larger. The Derale specs are not consistent and some specify BTUs and others GVWR - hence the call.
Their tech weenie there said he would consider the 15850 cooler pretty marginal for our applications as it is basically a 6 pass cooler with big, fat 1/2" lines. Given that these transmissions can apparently develop pretty high line pressure the oil moves through the big lines pretty quickly and doesn't cool much.
Instead, he suggested a stacked plate cooler (p/n 13960) where the oil moves through the plates vs just the lines and therefore has far more cooling capacity due to significantly greater surface area. It's the same general size and can also be mounted flat against a floor or frame rail (assuming it fits). I'm giving one of those a try and should have it tomorrow.
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 01-25-2018, 10:46 PM   #352
MIKESAD50
Re: Mike's 50
Wow, Been a while since I have posted anything.
I have been driving it except in the rain. Just got some blades for the arms I had that came with truck. I need to wire the wiper motor. I have 2350 miles on it and most have been problem free and minor at that.
I haven't really done much in those miles as far as repairs. I raised it about 3/4" all around. still need to get the JRI Shock rebuilt. I will be needing new rubber on the rear, no later than the 3,000 mile mark. Still have't made a good burn out video, yet.
It drives well and handles well, needs a brake bias adjustment, still needs a ECM dyno tune and a Interior. Been a BLAST to drive!
I will post up a picture and maybe that video soon.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 01-26-2018, 05:25 AM   #353
solidaxel
solidaxel's Avatar
Re: Mike's 50
Is the truck everything you expected?
What would you do differently?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-27-2018, 11:41 AM   #354
MIKESAD50
Re: Mike's 50
Not sure I would change anything about the truck, had no idea what to expect from the build, so happy for now, but like all these builds are they ever done?
I wish I would have completed the interior and bed before driving, now I don't want to take it off the road to work on it.
1950 3100 5 window
Old 01-27-2018, 12:37 PM   #355
solidaxel
solidaxel's Avatar
Re: Mike's 50
The last time I did that it took me 17 years to take it apart and paint it !
LS 3 4L70E
Old 02-11-2018, 09:49 AM   #356
MIKESAD50
Re: Mike's 50
Well needed to get some new rubber for the rear. got 2600 miles out of the them. forgot to get a picture of the new Michelin's. had to make another 25 mile round trip back to tire shop after noticing they mounted them inside out.
Looks like week after next I will be dropping of the truck to get interior upholstery done
1950 3100 5 window
Old 02-11-2018, 09:53 AM   #357
MIKESAD50
Re: Mike's 50
1950 3100 5 window
Old 02-12-2018, 01:21 AM   #358
ptc
ptc's Avatar
Re: Mike's 50
^^^^^^^^^^^^^^^ Looks like a perfect candidate for LONG SMOKEY BURNOUT!!!!!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 02-12-2018, 11:56 AM   #359
MIKESAD50
Re: Mike's 50
PTC, that is what got them to that point. lots of laughs and smiles along with the smoke.
1950 3100 5 window
Old 02-12-2018, 05:39 PM   #360
ptc
ptc's Avatar
Re: Mike's 50
Yup ---
Old 03-11-2018, 12:59 PM   #361
MIKESAD50
Re: Mike's 50
PTC, that from your badass truck?
1950 3100 5 window
Old 03-11-2018, 01:02 PM   #362
MIKESAD50
Re: Mike's 50
Dropped my truck off for interior last Monday 3/5/18. They say should be about 3 weeks. Here is a picture of the beginning of the seat.
1950 3100 5 window
Old 03-11-2018, 01:04 PM   #363
MIKESAD50
Re: Mike's 50
forgot the picture
1950 3100 5 window
Old 03-11-2018, 05:26 PM   #364
dsraven
Re: Mike's 50
those tires look worn out, musta let all the smoke outta them.
that's footstomper's line, I just beat him to it, haha
Old 03-14-2018, 07:23 PM   #365
MIKESAD50
Re: Mike's 50
Went to interior shop today to decide on thread color. My original plan was black leather with Ultra suede inserts with black stitching. They showed me Silver thread and decided to go with that.
The first picture is the silver thread. 2nd picture is black and the silver samples side by side. neither sample is ultra suede but leather, they forgot I was doing the Suede insert.
Carpet is going to be black square weave and the headliner will be suede, back wall will be leather also.
The partial seat picture is not my seat just another with same color thread on seams with my insert sitting there
1950 3100 5 window
Old 03-14-2018, 07:26 PM   #366
MIKESAD50
Re: Mike's 50
DsRaven
I could have gotten a few more hundred feet of Smoke out of them but got a puncture in one and had to plug it.
1950 3100 5 window
Old 03-15-2018, 12:25 PM   #367
dsraven
Re: Mike's 50
both leather pics look good. personally I would pic black on black because I plan to drive mine everyday and would worry that the light thread color would get dirty quicker. thats just me though. the light thread does pop.
Old 03-15-2018, 12:54 PM   #368
tinydb84
tinydb84's Avatar
Re: Mike's 50
Those seats look good! Awesome to see it running so well.
David
Instagram: myfabguy
Old 03-20-2018, 06:11 PM   #369
MIKESAD50
Re: Mike's 50
updates of interior progress
1950 3100 5 window
Old 03-21-2018, 01:14 AM   #370
iowaboynca
iowaboynca's Avatar
Re: Mike's 50
coming along nicely!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 03-21-2018, 10:06 AM   #371
MIKESAD50
Re: Mike's 50
Thanks.
Looking forward to getting it back.
1950 3100 5 window
Old 03-23-2018, 02:02 PM   #372
MIKESAD50
Re: Mike's 50
Got the truck back today. I like it!
1950 3100 5 window
Old 03-23-2018, 02:04 PM   #373
MIKESAD50
Re: Mike's 50
Couple more.
I hate that it rotates the pictures in wrong orientation.
1950 3100 5 window
Old 03-23-2018, 09:50 PM   #374
Advanced Design
Advanced Design's Avatar
Re: Mike's 50
The interior is looking good!
Advanced Design is offline   Reply With Quote
Old 03-23-2018, 10:59 PM   #375
mongocanfly
mongocanfly's Avatar
Re: Mike's 50
its looking great...coming along nicely...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
mongocanfly is online now   Reply With Quote
