Old 03-20-2018, 12:17 PM   #1
shoveldug
WTB 1967 Crank and water pump pulleys
Adding vintage air and power steering need the correct pulleys. Thanks Doug
shoveldug is offline   Reply With Quote
Old 03-20-2018, 11:48 PM   #2
michael bustamante
michael bustamante's Avatar
Re: WTB 1967 Crank and water pump pulleys
need a lil more information bud. what engine are you running? if a 350 what year did it come out of?
same question for all other small blocks as only the 283 and 327 v8s were avail in 67
1967custom
michael bustamante is offline   Reply With Quote
Old 03-21-2018, 03:30 AM   #3
shoveldug
Sorry ..... I put this post up real quick at work yesterday without giving it much thought. It’s a 1967 283. I will be picking it up at the machine shop later this week. I had them drill the crank snout and install a new harmonic balancer with stock configuration.
Old 03-21-2018, 04:52 PM   #4
michael bustamante
ok let me see if I have a 2 groove waerpump pulley for it and ill let you know.
did you install a power steer gearbox from a squarebody truck?
1967custom
Old 03-21-2018, 08:22 PM   #5
shoveldug
Yes I did. From a 79. I will need a 3 groove for the crank to run power steering? Or if you could enlighten me on how it would be best setup I would appreciate it.
Old 03-22-2018, 06:21 AM   #6
shoveldug
Should it be setup like this?
Old 03-22-2018, 07:15 AM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
I have a 3 groove crank if you need it. I think it's a long water pump though.
Old 03-22-2018, 07:57 AM   #8
shoveldug
Thanks.........I believe I need short.
Old 03-22-2018, 08:16 AM   #9
The Rocknrod
Moderator
Me too.
