Old 03-22-2018, 11:48 AM   #1
Classics Fan
‘72 Door Panels In ‘71 Jimmy?
In December I found and purchased a 1971 Jimmy Custom with 115,000 original miles. Overall it’s in great condition and runs and drives very very well. I have put dozens of hours into cleaning, detailing and addressing a myriad of things cosmetic and mechanical with the intention of flipping it next fall. That said, its become my daily grocery-getter and I might have to reconsider!
I have a question regarding interior door panels. This Jimmy has 1972 style that I believe are original to the truck. VIN is KE114S131492. Definitely a 1971, but seems probably a late run vehicle (21,492 consecutive number based on that number starting at 10000 in ‘71). Possibly the St. Lou’s assembly plant ran out of 1971 parchment door panels and substituted 1972 panels? I am OK with it, as I like the 72’s better anyway.
Anyone have any knowledge or ideas on this anomaly?
Classics Fan is offline   Reply With Quote
Old 03-22-2018, 12:32 PM   #2
flashed
Re: ‘72 Door Panels In ‘71 Jimmy?
The doors are 72 too .
flashed is offline   Reply With Quote
Old 03-22-2018, 12:40 PM   #3
SeventyOne
Maybe? I've never seen it though.
Your plate is also bolted on rather than riveted - that raises a red flag to me...
Additionally Blazer/Jimmy doors themselves are different from 71-72 and the door panel mounting holes are different. So if yours really is a 71, it would have 72 doors too (unless they also redid the holes on the door).
Have you ever had the door panels off?
Do the vins match to the frame?
SeventyOne is offline   Reply With Quote
Old 03-22-2018, 12:48 PM   #4
A1971Blazer
A1971Blazer's Avatar
VIN tag has definitely been removed/replaced....look next to the steering box on top of the frame...there should be some numbers stamped there....should be the same as VIN#
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is online now   Reply With Quote
Old 03-22-2018, 01:03 PM   #5
Classics Fan
I found the frame VIN and it’s a match. Leads me to believe the doors have been replaced even though the hinges to the frame appear original? I’ve had the door panels off a couple of times and haven’t seen anything that seems out of place. The truck shows other signs of accident damage and repair but it’s all confined to sheet metal.
Old 03-22-2018, 01:10 PM   #6
Classics Fan
SeventyOne: rereading your post, yes, the doors have been redrilled for the panels. I thought someone had done a slopppy job refitting them at some point. Apparently it was to replace them.
Old 03-22-2018, 01:14 PM   #7
A1971Blazer
Looks like you're good to go with that match...I'm guessing the doors were changed at some point..in the last 47 years....
1967 C10 Step side
1968 C10 Step side
Old 03-22-2018, 01:15 PM   #8
Classics Fan
Also thanks for the heads up on the VIN plate. It hadn’t struck me that it was bolted not riveted. Rookie move! Do you know if riveting is as easy and straightforward as it seems?
Old 03-22-2018, 01:17 PM   #9
Classics Fan
Thanks for your help!
Old 03-22-2018, 01:29 PM   #10
A1971Blazer
The VIN tag was originally riveted on with rosette style rivets....a lot of states...cities....counties are anal about that sort of thing....right down to it being illegal to remove or alter a VIN tag.....where I live..they couldn't care less....especially on a vehicle that old....If you have a title and have it registered already...I wouldn't give it another thought.....the only way it will come into play....is if you sell it to someone living where they are stricter about the VIN.....
1967 C10 Step side
1968 C10 Step side
Old 03-22-2018, 01:34 PM   #11
Classics Fan
Yeah, not a problem transferring title from Oregon to Washington state, registering and insuring. I’ll consider it a lesson well learned. My heart dropped when this conversation started!
Old 03-22-2018, 01:45 PM   #12
A1971Blazer
All good........nice Jimmy BTW...!
1967 C10 Step side
1968 C10 Step side
Old 03-22-2018, 02:04 PM   #13
Classics Fan
Thanks! I think I picked it up right. At the time it wasn’t nearly as clean as it is today. Original 350 rebuilt in the late 90’s at 85,000 miles along with the same for transmission. Mild updates to both at the time. Uses absolutely zero oil and the undercarriage/engine bay are now as clean as the body. New rear springs to eliminate a sagging butt and brakes have been the biggest and most necessary mechanical needs that I’ve addressed. I was actually looking for more of a project when I found this one. It’s a hoot to drive but the mileage is horrible... go figure. Definitely leaving a carbon footprint! ��
Old 03-22-2018, 04:56 PM   #14
richard2717
Equal opportunity joke ofender
richard2717's Avatar
I am guessing they have changed the laws on the original rivets? I see there are several ads on Ebay for new ones. Not cheap but might be a solution for some.
https://www.ebay.com/sch/i.html?_fro...ivets&_sacat=0
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 03-22-2018, 08:49 PM   #15
pound41
would not shock me if the 72 doors were original to the jimmy. I have a matching numbers 69 camaro that has a block casting that was spected for a chevelle. I have A matching numbers 85 monte carlo SS that has mostly 86 parts. If you go to the books Chevrolet by the numbers where the author interviewed line workers They said when we ran out of parts they came from other places what were we going to do stop the whole line.
pound41 is offline   Reply With Quote
Old 03-22-2018, 09:35 PM   #16
A1971Blazer
I bought a new Z28 in '74......the factory went on strike so it came way late in the year....it had the HEI that didn't officially come out until the '75 model year...
1967 C10 Step side
1968 C10 Step side
Old 03-22-2018, 11:16 PM   #17
too much stuff
Roadtrip!
too much stuff's Avatar
The doors could be 70, 71, 72. Blazers had the extra screw under the wing window. The door panels are 72. I doubt the factory would have put them on since they would have had to change the window crank, door release, drill out the door for push in clips etc...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-22-2018, 11:40 PM   #18
solo72
solo72's Avatar
Nice Jimmy! Looks similar to mine! Have a picture of the Spid?
solo72 is offline   Reply With Quote
Old 03-23-2018, 01:06 AM   #19
Classics Fan
Here’s the Spid. Fairly well equipped with the manual throttle the most rare from what I’ve seen. No tach unfortunately.
I like your Goat in matching Hugger Orange no less! Judge? I sold my 71 Camaro Coupe with 14,000 original miles to make room for the Jimmy. Still have my 74 Ranchero 500 with WAY more in it than I will EVER recover!
Old 03-23-2018, 01:17 AM   #20
Classics Fan
Are you saying only Blazers have the screw under the wing windows? My Jimmy has them... does that possibly point towards door replacement?
I checked with the PO who had possession since the late 90’s. He said the current door panels were on it when he got it.
Probably never know for sure.
Old 03-23-2018, 07:38 AM   #21
richard2717
It is hard to see from the picture but if it has the big plastic screw base at the wing window it is a 71 down if it is metal and indented it is 72 only from everything I have read. door panels would be easy enough to change. The 1st pic is of the 72 door. The 2nd pic is of the 71 down blazer only wing screw & bezel
Members I have met.
Old 03-23-2018, 08:31 AM   #22
too much stuff
Roadtrip!
I am thinking yours may have had a body swap at one time. With the screws holding the VIN plate on and the SPID looks like a repro to me. Not trying to imply anything bad, just my opinion. The manual throttle was actually somewhat common on the blazers/jimmys I have seen.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-23-2018, 08:44 AM   #23
briank
Jimmys have the screw as well. I have a 70..same color, hugger orange. Your spid font looks different. Ive attached a picture of mine...codes on mine start with a different numeric??
briank is offline   Reply With Quote
Old 03-23-2018, 10:17 AM   #24
simicrintz
Following this. I am way new to these rigs and have a lot to learn, but this does seem peculiar (VIN plate mounting, font) from what I have learned so far on here.
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 03-23-2018, 11:24 AM   #25
Classics Fan
I dunno. Obviously this rig has had some interesting events in its life. What started as a question about door panels has evolved into something deeper.
