03-22-2018, 01:30 PM | #1 |
NV4500 swap Muncie SM465
Im considering swapping my current Muncie sm465 for a NV4500 and just looking for general advice. Can i keep the stock clutch? Stock input shaft specs? How much do.i have to shorten driveshaft? Shifter alignment?
Any pther tips and advice much appreciated. |
03-22-2018, 02:15 PM | #2 | |
The Older Generation
Re: NV4500 swap Muncie SM465
Read this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=673588 LockDoc
03-22-2018, 06:29 PM | #3 |
You might want to search here, as well as go to Advance Adapters web site and get their conversion guide. As I recall 93-95 and 96 up are a bit different in the bolt pattern and reverse on the later trans had a synchro as well as a slightly less steep first, etc. 95 was a transition year if I recall so its a bit unique.
Oh, and Dodge used them so there are Dodge versions that I think need the input shaft replaced to work on GM. |
Tags |
clutch linkage, muncie od 65 c10 swap, nv4500 5 speed |
