Old 03-24-2018, 06:51 PM   #1
dmjlambert
dmjlambert's Avatar
Re: Temp gauge help
I believe you would need to match the resistance of the original part in order for the gauge to read accurately from one end of the scale to the other. To test, heat some coolant on a stove and measure with a candy thermometer and dip the sensor in it and see how the gauge reads. If the coolant is very hot, such as 240, you will want the gauge to be showing a hot reading. It may be easier to get a new gauge or pull the stock resistor from a used cluster. It could be a member here has a stack of junk clusters and can offer you one. I see the LMC catalog has the gauges for $30 but don't know if they come with the resistor.
Old 03-24-2018, 07:27 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Temp gauge help
I need to add that the statement in the photo that states "the silver post is grounded to the cluster" is not always true. If the temp gauge had a retainer clip on it from the factory and it was removed, the temp gauge has now lost its ground to the cluster. Without the retainer, the silver post has nothing to connect it to the cluster tin. This is true with porcelain resistors only as far as I know. You can run a short ground wire from the silver post to the tin mounting screw and should have a good ground, if everything else works as it should.
Anytime someone ask about a temp gauge problem, I will ask if they have a fuel gauge problem as well or the other way around?
If you have the correct temp sending unit, meaning for the truck as built, the 90 ohm resistor on the back is the correct resistor for the gauge.
Also note that there are some manufactures of aftermarket gauges that require no resistor as it is built in to the gauge. Having a resistor on one of these temp gauges will make them read incorrect.
Hope this helps.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 03-24-2018, 08:08 PM   #3
s10mk
Re: Temp gauge help
Hope this helps.
Hi there, my fuel gauge was working properly. It was just that the temp gauge would peg all the time when power was applied, on or off the vehicle. I tested it on the work bench with a 9 volt battery. But anyway, I think I'm in buisness, I took apart an old delco radio and I found a 100 ohm resistor. I installed it in the gauge, and it appears to be working correctly. I'm gonna instal it in the truck and test it out. Thank you!
2009 GMC Sierra 1500
2006 Buick Lacrosse
1987 Chevrolet V10
1972 Chevrolet c20 350/350
1967 Chevrolet Biscayne ls3 swapped
s10mk is offline   Reply With Quote
Old 03-24-2018, 08:13 PM   #4
s10mk
Re: Temp gauge help
Oh, and when I said I tested it..... when I apply power, from a 9v battery, the gauge reads cold. When I ground the sending unit wire to the gauge, the gauge pegs hot. Now I'm gonna install it in the truck to see how accurate it actually is. I'll report back.
2006 Buick Lacrosse
1987 Chevrolet V10
Old 03-24-2018, 08:22 PM   #5
57rookie
Re: Temp gauge help
Here is my 2 cents worth. For the cost of a new repo gauge I would go this route. I build on a budget like everyone else but your time and frustration level is worth something too. LMC sells replacement gauges for a reasonable price. I would go this route unless you are retired and have nothing but time on your hands....
57rookie is offline   Reply With Quote
