Old 07-11-2014, 09:18 PM   #26
mechanicalman
Re: Frame shortening
Originally Posted by the ideaman View Post
We shortened the frame on my '67 using the frame stiffeners from Early Classic Enterprises. Once the bed is off, it only took about 12 hours with cleaning, measuring and welding. We lifted the back of the cab off the back mounts and tilted it forward a couple inches to get at the frame. I wouldn't hesitate to do it again.
More good info, thanks!
mechanicalman is offline   Reply With Quote
Old 07-12-2014, 02:45 AM   #27
mechanicalman
Originally Posted by Oldtruckfanatic View Post
I'm doing a 72 like that now we cut the frame section off and slit the corners I'm working on stepping the sides now and I will step the upper and lower flanges and then tig weld the slits at the corners. Hopefully it will slide inside the other frame section and I will weld it back together. I got the idea while putting a gooseneck hitch in a guys 08 silverado.
Trying to picture what you are doing there, sounds like the step bends could prove difficult but if you think about anything long enough it can usually be done easier than one would think on first sight. Sounds like it will fit together like a gutter drain pipe only 3 sides instead of 4.
Makes me wonder if there is a rectangular box steel out there somewhere that would simply slide over the two frame sections as an external box. Square up the frame, clamp or bolt it, and weld.
Old 07-12-2014, 03:08 AM   #28
Fitz
Originally Posted by mechanicalman View Post
Thanks for the link, Fitz. I think I'm at least going to raise the cab if I want enough frame rail exposed to weld the top and to use the frame stiffener channels to align/reinforce it properly. I think I'm going to have to move the rear cab mount brackets as well.
See there I'm learning! LOL
We all do!
Fitz is offline   Reply With Quote
Old 03-29-2016, 10:11 PM   #29
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by Turbo1dr View Post
This is the method I'd do if I were to shorten my frame. There are several videos showing all the steps but this one is about cutting the frame below the cab. Watch all the video's and you will see how easy it really is.
LMC Truck: Shortbed Conversion [S7 Ep. 3-3] - YouTube
Thanks for the video link.
I like his reasoning for rounding the corners to prevent cracks from starting.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-29-2016, 10:41 PM   #30
dacavy
I have cut 2 frames. One I did behind the cab because I didnt want to remove the cab, and the other was under the cab like Stacey did. Both worked out great it just depends on how far you want to take the truck down. Youll do great if you just follow the advice (and measurements) of all the guys that have successfully done the shortening. GOOD LUCK!!
dacavy is offline   Reply With Quote
Old 03-30-2016, 02:50 AM   #31
dazza
dazza's Avatar
I know you said you have a short bed already and maybe you've seen this, but amazing work here...
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 03-18-2018, 07:49 PM   #32
LostMy65
LostMy65's Avatar
So, has anyone used these?
https://www.summitracing.com/parts/c...2rfs/overview/
Old 03-18-2018, 09:45 PM   #33
rjs53
Just cut mine under the cab, removed a foot. I was going to do the Stacy David cut, but the frame on the pass side has a lip in it. Mu cut would have ended up in the middle of it. I did a straight cut and boxed it, couldn't find any channel to sleeve it, unless I bought a full stick. Glad I checked this post, saw that CPP sells some precut. I'll get it and go back in and put them in for added protection. Good luck with your truck.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 03-18-2018, 09:51 PM   #34
rjs53
Just noticed this is a old post, oh well found something new
2003 Dodge 2500
1969 C10
Old 03-24-2018, 11:49 PM   #35
LostMy65
LostMy65's Avatar
Yep, old threads doesn't mean out of date information.
I was hoping to hear if anyone has used those stiffeners and how nice did they fit?
Old 03-25-2018, 12:53 AM   #36
RedRider
RedRider's Avatar
They look like the ones Brothers uses in their shortening kit
1970 C-10 "Old Yeller"
RedRider is offline   Reply With Quote
Old 03-25-2018, 01:02 AM   #37
rjs53
Hate to throw money away, but I'm getting ready to order some stuff from Summit and for less than $40 I think I'll take a chance.
2003 Dodge 2500
1969 C10
Old 03-25-2018, 06:21 AM   #38
tutone
tutone's Avatar
Click on my build thread. I used the ECE stiffeners and there is detailed instructions on the process. Best money I spent.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1969 C10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5
tutone is offline   Reply With Quote
Old 03-25-2018, 10:56 AM   #39
72Cheyenne454
72Cheyenne454's Avatar
I shortened my frame under the cab. I unbolted all the cab mounts, loosened the core support mounts and lifted/tilted the cab up to give me some working room.
A few pics...
My build -
http://67-72chevytrucks.com/vboard/s...d.php?t=379889
72Cheyenne454 is offline   Reply With Quote
Old 03-25-2018, 11:07 AM   #40
72Cheyenne454
And finished -
Old 03-25-2018, 12:26 PM   #41
Coley
Coley's Avatar
...I'm kind of glad I'm not into this trend, lol.
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 03-25-2018, 01:26 PM   #42
leddzepp
Moderator
leddzepp's Avatar
That sure is a lot of work! Looks like you did a great job.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-25-2018, 03:20 PM   #43
LostMy65
LostMy65's Avatar
How snug do they fit before you weld them in?
Old 04-25-2018, 10:53 PM   #44
LostMy65
LostMy65's Avatar
I got my ccp stiffeners from summit today.
Very tight fit. So tight, I was at first concerned.
But they fit so tight, I had to tap them in with a hammer.
They are pretty heavy duty too.
Now to cut a perfectly good longbed frame in half.
Old 04-25-2018, 11:42 PM   #45
rjs53
Same here, got the frame inserts and they do fit snug. I think they'll work great.
2003 Dodge 2500
1969 C10
Old 04-26-2018, 04:59 AM   #46
BCOWANWHEELS
gonna do my 72 c10 asap
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
