03-25-2018, 05:16 PM | #1 |
WTB Big Block power steering pump and reservoir
Looking for a power steering pump and reservoir for 1971 402 big block. Let me see what ya got.
03-25-2018, 07:02 PM | #2 |
Re: WTB Big Block power steering pump and reservoir
I will look and see what I have. Hopefully I can help you out. Thanks
03-26-2018, 12:02 AM | #3 | |
Always on the hunt...
$125. / BBC p/s pump and fender reservoir. (no mounting brackets or pump pulley) $175. / BBC p/s pump, fender reservoir and pump pulley. (no mounting brackets) $275. / BBC p/s pump, fender reservoir, pump pulley and both mounting brackets. |
03-26-2018, 12:04 AM | #4 |
Last two pics...
03-26-2018, 02:05 AM | #5 | |
03-26-2018, 03:24 AM | #6 |
Okay, we'll stand by for his reply back, he could also end up purchasing the needed parts from daddymoo2. We are getting ready to post a multi item 72 big block parts F/S thread on the parts board and will add these BBC power steering parts to that thread should BLT-NT-BOT pass, will place you inline. Mel
03-26-2018, 10:31 AM | #7 |
BLT-NT-BOT: Here are the pics. Thanks Off 72 402 Asking 260.00 Shipped. Thanks Don
03-26-2018, 01:29 PM | #8 |
Per our earlier phone conversation, here are the A/C brackets that we can pull from that same big block truck. Will offer the pictured 9 pc. BBC A/C bracket setup to you for $275. if purchased along with the other offered big block P/S parts. Thanks, Mel
03-26-2018, 01:56 PM | #9 |
With the bracket setup still installed it's kinda hard to tell what you will be receiving, here is a picture of another (previously sold) 9 pc. BBC A/C bracket setup. After removal, you would be getting these nine pump mounting brackets, a lot of guys run this big block setup as a 7 pc. without the two pc. rear brace rod and manifold bracket (see red arrows). The compressor will mount and be supported fine without these two braces, if you want to go with a 7 pc. bracket setup, we will go $245. w/o the two marked braces. Mel
03-26-2018, 09:16 PM | #10 |
03-26-2018, 09:59 PM | #11 | |
Thanks Jothan |
03-27-2018, 07:58 AM | #12 |
Don't want to hijack the thread.
Mel, I'd be interested in the two brackets you have circled in red above if you decide to separate from the others. PM me if you'd like. Thanks. |
