Old 03-28-2018, 06:03 AM   #16
Andy4639
Old member
Andy4639's Avatar
Question Re: Ramp truck winch??????????
Originally Posted by outfield View Post
Depending on the size of the winch Warn recommends a battery with at least 650 cases. Do you kno the cra of your 6 volt batteries? You would add the two together to get the total. Make sure to run both winch battery cables to the battery terminals. Don't run the ground cable to the frame. Try to mount the batteries as close to the winch as possible to avoid voltage drop through the cable length too.
Thanks for the info. No I don't know them off the top of my head but will check.
Why do you need to run the ground back to the truck battery? Just curious?Yes the 2-6 volts are right beside the winch with no more cable than needed.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
