HELP, 72 K5 blazer front spring question????
So, Im new to the K5 blazer world, but love working on my newly aquired, about a year ago 72 K5.
So I have alot of creeking, crackling noise coming from my front suspension. I crawled under the chassis and found a "bracket" at the rear of the driver's side leaf spring. It is making contact with the spring, metal on metal. There are holes on the passenger side frame but no bracket is there, ONLY the drivers side. I have posted a picture of it, I sprayed white lithium grease on it hoping that it helps with the noise. Now my help needed questions..... 1. Is there supposed to be on on the passenger side too? 2. What's is it's purpose? 3. Can it or should it be removed? 4. It is metal on metal, is there supposed to be a rubber bushing or something on it? Thank you for anyone who can answer my dumb questions! |
Roadtrip!
![]() Join Date: Feb 2003
Re: HELP, 72 K5 blazer front spring question????
It is supposed to be there. It is incase the spring breaks it won't throw you into oncoming traffic. There should be a cage on the front of the spring also. Only on the drivers side. It shouldn't be hitting the spring.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Ok, great info, and yes there is a cage in front of drivers side spring.
But if its not suppose to be hitting the back of the spring, why is mine hitting it? What is wrong? Thank you....... |
sagging front leaf springs?
![]() Join Date: Feb 2010
Here's one idea. Check the front bushing on the drivers side leaf spring. If it is worn out it is allowing the spring to move back too far.
Keith
71 Blazer 4X4 (unmolested, all original (including paint) 74,000 mile barn find) 67 Camaro RS SS (unmolested, all original (including paint) 81,000 mile barn find) Keith Riel |
Well, looking at the bracket closer, the holes are elongated, therefore I was able to move it back about 3/4 inch. Doesnt make contact and no more metal on metal and all the noise
The bushings are gone most likely
#8 | |
I agree with these guys. You have original springs, and probably well worn original rubber bushings, on what looks to be a well-used ( but REALLY cool looking) truck- getting your spring and shackle bushings in order should probably be one of your first projects. If you are planning to lift it, or swap springs, then the new springs will come with bushings, but the upper shackle bushings (front and rear) need to be purchased separately, and should be changed out at the same time you do the spring bushings; otherwise the new spring bushings will just intensify and accelerate the potential failure of the upper shackle bushings. Lastly- don't mix bushing materials- If your springs use poly bushings, then use poly on the shackles, too. If you use OEM rubber on the springs, then match them with rubber on the shackles. |
