6 lug 12 bolt
On the GM 12 Bolt truck rear end used in 1960-66 trucks, was 6 lug or 5 lug standard?
Re: 6 lug 12 bolt
My 63' C-10 is a 12 bolt rear-end with 6 lug wheels. But I think the later model trucks had 12 bolt with 5 lug wheels.
![]() Join Date: Jan 2011
Re: 6 lug 12 bolt
6 lug was standard on 60 to 66. 5 lug did not come about till they went to front disc brakes. 71 or 72 for that.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
60-66 Nut
Re: 6 lug 12 bolt
The '60-'62 Chevy Apache 10 trucks used the Eaton HO322/33 differential which were 6 lug. The '63-'70 C10 truck 12 bolts were all 6 lug.
Re: 6 lug 12 bolt
6 lug.
Re: 6 lug 12 bolt
All, do you have any documentation to prove this? The reason I ask is that I went to my local gear shop to order parts needed to rebuild my 1965 Suburban 12 bolt 6 lug GM truck version rear and discovered after the parts had shipped that the axles sent were 5 lug. They think I should have told them I needed 6 lug and I think they should known and asked which I needed if there was a question. Now they are expecting me to pay for round trip freight to and from Alaska and a restock fee.
Re: 6 lug 12 bolt
Here is my thoughts on this with more than 40 years of working on cars and trucks. The more exact you are about what you need and the more information you give the parts guy the better your chances of getting the right stuff. The parts books can be a bit lacking and the axles he ordered may say the fit your truck. Not everyone knows what goes in every vehicle and when they get more than 50 years old a lot of folks have never seen or delt with one. If I was in your position I would just have a conversation about you not giving them enough info and them not asking about the axles and see what can be worked out. Everyone has a part in this not being the right stuff and everyone needs to accept part of the responsibility for it.
Jimmy
#8 | |
Never Ending Projects
Re: 6 lug 12 bolt
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Re: 6 lug 12 bolt
I had much more info written down to give the gear guys (numbers off the case and tubes, gears, measurements, etc). They said no need, they had all the info they needed.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: 6 lug 12 bolt
I have a bunch of original literature for 60-66. You can go to gmpartswiki.com and look in the original parts books. I agree with you however, the seller should have known or had questioned you as to your preference.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Re: 6 lug 12 bolt
Well, I would tell them that obviously they didn't otherwise they wouldn't have sent the wrong axles.
1965 GMC 910 Short Fleetside. |
#12 | |
I'm just glad to be here!
Re: 6 lug 12 bolt
The codes on the axle tube could have lead them down a path of using a later model housing that was 5 lug standard. Now, that being said, the later model 12 bolt axle (mid-70 and newer) are wider than the 63-mid 70 axles.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
