Capacity of dropped spindles
I have a 68 GMC Burb, that has a 73 Malibu SS-454, 4-Speed Wagon Motor, I was about to trade it for an LS but when I found out via Research it’s a keeper, (one of 60), Has been gone through and is now a 468, My question is since it’s heavier what spindles would be strongest? Was told not to go 2-1/2 or 3”, due to weight, it’s about to go through full redo, as soon as we move to new place. I’ve seen many BBC A and F Body’s with dropped spindles, but they aren’t trucks.. I thank you all for any answers or input,
It will sit on 20s, 2600 bags and HD A arms, maybe go with Lay arms,it will be just close to layin’ out, Roy PS it’s already sittin on a Pro Hopper 2 pump 4 dump system and I have got everything to convert to bags, I carry My Hayabusa in the back so I can only bring the floor in rear up 2”. Posted via Mobile Device |
#2 | |
The Older Generation
Re: Capacity of dropped spindles
I had to look up Hayabusa... ![]() I don't know about the 3" but there are a lot of big block trucks running around with 2 1/2 dropped spindles. If you don't get any replies I will try moving this to the suspension forum. LockDoc
#3 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Any 2", 2.5" or 3" drop spindle will be fine. I prefer ECE (Early Classic Enterprises), Belltech, McGaughy's or Western Chassis. Is your truck still drum brake or has someone converted it already? Buy 63-70 conversion spindles for the easiest install. If its been converted to disc already,... you will need to know what year stock spindles are on your truck now.
It’s drum but I will move to Disc CPP kit, The question is because the stress point on the 3” is lateral if it’s cambered but I believe it’s gonna be fine, I know certain brands are thicker. I will probably go with 2-1/2” but I wanted to keep it as close to NOT bottoming out , but being able to get it down, Lock Doc here is a pic of one of my bikes I do Custom airbrushing so I’m gonna do truck like bike.
