Old member
I loaded up the ramp truck yesterday with my 2 Schwinn chopper bikes and 1 pedal car to take to the Greenville SC Car's & Coffee this morning. It didn't make it but I got it back home and drove the 71 instead.
When we got back home I looked at everything under the hood and the only thing I could figure was the HeI was still running on the factory resistor wire. Sure enough after pulling the harness out and unwrapping it I found what I had thought. Stripped it out to the fuse block and re wired it to the HEI and it is running nice now. Maybe next month it will make it. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Apr 2016
Re: Almost
Good find. Mine was like that and ran fine for the first few months. Then I rewired it like this.
http://67-72chevytrucks.com/vboard/s...d.php?t=708975 |
#3 | |
Old member
![]() Quote:
That's what I did except I cut the resistor wire off at the connection and tied into it. Took this on the way over before I turned around ![]()
Re: Almost
The 56 pedal car looks just like either of my 2 real 56's
Old member
Those look good man!
I had the pedal car built for my dad's 56! The pedal car is from Speedway motors for $169.00 ![]()
Old member
Ok winch batteries are wired into the truck battery and charging. I put a contactor in line with the + cable to turn it on/off with from the dash. Lighted switch on dash lets me know when it's on are off.
May put a 50amp fuse in line with it also. ![]()
