Old 04-02-2018, 04:48 PM   #1
Hayden’s72
Secondary’s on edelbrock 600cfm carb not opening
I have a 1972 c20 with a sb350. The carb is a 600cfm edelbrock 4barrel. I have noticed that it doesn’t kick down a gear when gunning it and doesn’t have that “feel” that the secondaries are opening. So sure enough I opened her up and looked into the carb and they are not opening. Have any of you had this prob? How can I fix it? Thanks.
Hayden’s72 is offline   Reply With Quote
Old 04-02-2018, 04:50 PM   #2
demian5
demian5's Avatar
Re: Secondary’s on edelbrock 600cfm carb not opening
Sounds like your kickdown cable isn't adjusted properly. Post a picture of the cable setup and a picture of the carb from the top as well, then we know what you are dealing with and can help..
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-02-2018, 04:50 PM   #3
Hayden’s72
Here are some pics
Old 04-02-2018, 05:38 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Looks you have a secondary air valve in your carburetor. If so, cranking the throttle open won't show the secondaries opening up, because there is no vacuum pulling the secondary air valve open if the engine isn't running. With the throttle held wide open, use a pencil or some other poking device to open the air valve. Then you will see if the secondaries are opening.
~Steven
Simi Valley, CA
Old 04-02-2018, 05:52 PM   #5
gvw5400
gvw5400's Avatar
One thing to check is the choke adjustment. When the engine is warmed up does the chokestat open the choke plate all the way? If not the secondaries will be lock out.
Also check that the transmission downshift cable pulls all the way forward at wide open throttle. Also welcome to the site!!
All the best,
Dirk
gvw5400 is offline   Reply With Quote
Old 04-02-2018, 05:55 PM   #6
Metaldoc
Metaldoc's Avatar
Make sure the butterflies are not hitting a gasket, just got a new carb with that issue.
Metaldoc is offline   Reply With Quote
Old 04-02-2018, 06:27 PM   #7
demian5
demian5's Avatar
He has the tons-o-fun weighted secondaries. I'm battling the secondary opening of those as well. But I know mine are working.
That vacuum line for your vacuum modulator looks almost falling off the nipple on the intake.
Make sure the choke is open. You shouldn't need to see down the hole to verify the secondaries are opening, just watch your linkage. How about a picture of where the kickdown cable is attached to the bracket so we know what kind of adjustment you have?
And try and get the pictures oriented right by doing a test post before actually posting.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-02-2018, 06:33 PM   #8
demian5
demian5's Avatar
And this shows how to adjust the kickdown cable. Best one with images of the tab I have seen.
http://forum.73-87chevytrucks.com/sm...?topic=31453.0
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-03-2018, 02:12 AM   #9
stsalvage
Scrapper 1
stsalvage's Avatar
I found out something with my 1972 3/4 ton 350 with the th350.The Vacuum modulator on the back of the trans is not adjusted right or the governor is set to tight.That can cause a lot of no kick down my 2 speed power glide shifted harder then any of the GM transmissions mine was all linkage no cables No lag
stsalvage is offline   Reply With Quote
Old 04-03-2018, 11:54 AM   #10
RichardJ
Any transmission problem would be a separate issue.
The Air Valves that you can see looking down into the carb are not connected to linkage or anything else. That assembly with the counterweights on both ends just lays in there above the secondary throttle blades. They open by airflow not vacuum. They open gradually as air flow and rpm increases. Without these valves, the engine would fall on its face at lower rpm when you stabbed the throttle. WHEN DRIVING.
The Edelbrock AVS, Air Valve Secondary. has the valve mounted higher, in the air horn and has adjustable spring tension instead of weights.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 04-03-2018, 01:13 PM   #11
davepl
davepl's Avatar
I think it's covered above, but to be pedantic about it, that's not a "mechanical secondary" carb so they will not open by operating the carb linkage.
They operate from a vacuum diaphragm that is energized by air flowing throw the carb primaries. The more through the primaries, the more the secondaries will open. So you can't just check it easily on a bench like that.
Remember also that even on the car they will not open until there is a demand, and your primaries can likely feed the first 275hp of power, so they may not open at all until higher RPM at full throttle anyway.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-03-2018, 01:30 PM   #12
demian5
demian5's Avatar
The secondary butterflies open (mechanically through the linkage) and the vacuum created by them opening, pull the butterflies open. The weights are in place of the spring and cause resistance to the vacuum pull, to assist with a smooth transition.
1986 C20 Scottsdale
Instagram: C10sofOC
