01-04-2018, 08:33 PM | #26 |
Re: Aluminum radiator
For those who may be interested here is a link to a lengthy post on this subject.
http://www.pirate4x4.com/tech/billavista/Cooling/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-29-2018, 11:31 AM | #27 |
My new ECP unit arrives today and I was wondering what if anything can be done to keep it from corroding on the outside? Living out on the coast, aluminum gets looking pretty jenky pretty quick! My carb, trans case, alternator, etc all have started getting that white speckled corrosion on 'um after only 6 months on the road. Sucks!
03-29-2018, 11:53 AM | #28 | |
Posted via Mobile Device Last edited by Z10; 03-29-2018 at 12:03 PM. |
03-29-2018, 12:02 PM | #29 |
Cool! I'll look it up. Thank you!
03-29-2018, 08:18 PM | #30 | |
If you would, post pics of weld quality, fittment, and give your overall impression of the quality of the radiator. I am strongly leaning towards buying one of those radiators but I have never seen an actual review of them here so that would be very helpful to those considering buying one. Thanks!” |
03-30-2018, 09:13 PM | #31 | |
I took a handfull of shots of the weld seams, in my photo albums. |
03-31-2018, 09:00 AM | #32 |
Where are your photo albums located?
03-31-2018, 09:38 AM | #33 |
03-31-2018, 07:50 PM | #34 |
That is the radiator I put in. I don't know about corrosion on the outside, I would be interested to know also. For corrosion on the inside I wrote an email to ECP a while back and asked them if the stuff I read on the internet about sacrificial anodes is a real thing, and they wrote back and said yes and suggested I get one. I got this one: https://www.amazon.com/dp/B001GR09S4/
I don't know what it should look like after being in the truck for a year. I went and pulled it out just now and this is what it looks like. I don't know if this shows the sacrifice is happening. Poor picture, sorry about that. I was trying to take a picture with one hand and plugging the hole with my finger and making a mess. The anode has a brown coat of stuff. I run 2/3 coolant and 1/3 water, and have a coolant reservoir, so I probably don't have a very corrosive environment in there. Do you plan to use a sacrificial anode? |
03-31-2018, 09:01 PM | #35 | |
How 'bout it - what's everybody else doing as far as interior corrosion prevention with an aluminum radiator? |
03-31-2018, 09:15 PM | #36 |
Zinc Anode Drain Plug... for internal corrosion
Stan 67 swb BLU MULE posted via flip-fone |
03-31-2018, 11:10 PM | #37 |
"additive that can be added periodically" -- that would be any high quality coolant such as Prestone, it has corrosion inhibitors that wear out after 2 years. I added that zinc rod drain plug just as an extra measure. One thing I've noticed with my high concentration of coolant is the level of coolant in the coolant reservoir does not change at all with the engine hot or cold. No boiling, no expansion, and all the air is burped out of the main system.
I think it would be good to hear if anybody is doing anything to reduce external corrosion, other than painting the whole thing including the fins. Last edited by dmjlambert; 03-31-2018 at 11:58 PM. Reason: ...if anybody is doing anything to reduce external corrosion |
03-31-2018, 11:33 PM | #38 | |
http://forums.corral.net/forums/general-mustang-tech/1046473-preventing-electrolysis-aluminum-radiator.html#/topics/1046473?page=1 Posted via Mobile Device |
03-31-2018, 11:49 PM | #39 |
Yes, head explosion effect, I had that, too. Makes me wonder if it's all a bunch of baloney.
04-01-2018, 08:44 AM | #40 |
Back to Rads. I have a Griffin rad in my truck and although it cools my 408 small block ok the fit wasn't as good as it should be. I find that it needs more airflow than a copper rad ie in stopped traffic. The worn out, plugged up 40 year old 3 core that i had before,cooled it too. I would probably go with a new 3 or 4 core copper rad next time. All the studies in the world can't convince me that aluminum cools better.
04-01-2018, 10:01 AM | #41 |
Was in cooling tower industry for 35 yrs , We used zinc anode on all watertouch applications.....
04-01-2018, 06:29 PM | #42 |
Here is something else to consider. I've used these on the last couple of builds.
http://www.acdelco.com/auto-parts/ve...seal-tabs.html
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
04-01-2018, 06:37 PM | #43 | |
04-01-2018, 06:44 PM | #44 |
Hmmm? It's working for me. Try searching this: ACDelco COOLING SYSTEM SEAL TABS
04-03-2018, 05:06 PM | #45 | |
