Old 04-03-2018, 06:26 PM   #1
KyleSeal
KyleSeal's Avatar
Paint Divider Template
Does anyone have a paint divider template for the 67-72 trucks? I recently picked up the paint divider trim from a part out truck in great shape. Need to drill the holes for the trim clips now, but is there a template out there I can use?
This is the divider that goes on the back of the cab at the bottom of the drop rail from driver to passenger side.
C10 Club Virginia President
Toano VA
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 04-03-2018, 07:27 PM   #2
B. W.
B. W.'s Avatar
Re: Paint Divider Template
Here's what I have:
Measured on a 72 C20
paint divider trim on back of cab: chrome trim is centered 1&5/8" above body line on back of cab
bottom of chrome trim lines up with the color split on the door, NOT the bottom of the drip rail
Measured from the edge of the door jamb, NOT the inside of the drip rail:
#1 rivet 1&1/4" from jamb
#2 rivet 5&1/4" from jamb (3&7/8" from #1)
#3 rivet centered between 10&3/4" and 10&7/8" from #2 ( 5&1/2" from #2)
#4 rivet 18&1/4" from jamb (7&1/2 from #3)
#5 rivet 9&1/2" from #4
#6 rivet 9&1/2" from #5 (this is the center of cab, repeat on other side)
From a forum member (GM assembly guide) Sorry, don't know who.
measuring from the center line of the rear of cab:
2.16" down from window lip (very top with glass out?)
1st rivet 1.5" from CL
2nd rivet 9.5 from CL
3rd rivet 19" from CL
4th rivet 28.5" from CL
5th rivet (on cab corner) 0.93" foreward from rear of cab
6th rivet (one closest to door) 4.5" from rear of cab
B. W. is offline   Reply With Quote
Old 04-03-2018, 10:40 PM   #3
KyleSeal
KyleSeal's Avatar
SWEET man thank you so much!!!
Originally Posted by B. W. View Post
Here's what I have:
Toano VA
67-72, paint divider, template, trucks
