Old 03-19-2018, 07:58 PM   #1
SeventyOne
WTB: Parchment Door Escutcheons for '71
Need 4. Who's got em?
SeventyOne is offline   Reply With Quote
Old 03-21-2018, 06:30 PM   #2
SeventyOne
Re: WTB: Parchment Door Escutcheons for '71
bump
Old 04-02-2018, 12:58 PM   #3
SeventyOne
anyone?
Old 04-02-2018, 06:40 PM   #4
tim71
tim71's Avatar
I asked the same question about 4 or 5 months ago and no one responded, parchment escutcheons must be fairly scarce. I ended up doing a little surgery on some after market escutcheons and it worked out ok.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 04-02-2018, 08:56 PM   #5
med.bronze
med.bronze's Avatar
I don’t mean to hijack this thread but what do you mean by “surgery “? I’m in the same predicament with finding some and considered just getting some saddle colored aftermarket ones and dying them parchment.
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350
1971 K-10 Custom Deluxe
1971 K-10 Custom
med.bronze is offline   Reply With Quote
Old 04-03-2018, 01:19 PM   #6
SeventyOne
I have both saddle and parchment aftermarket ones...would love to see the surgery you did too.
Old 04-03-2018, 07:47 PM   #7
tim71
tim71's Avatar
My original escutcheon is the one on the left in the picture. As you can see, the aftermarket escutcheon is much thicker(or taller). You also most likely notice that it also is not a perfect color match. What I did was to carefully grind the bottom of the aftermarket escutcheon on my bench grinder. The ground surface sits against the door panel and you can't tell it's been thinned down if you grind it evenly. When I put my handles back on, the escutcheon is held tight to the panel and both the door and window handles operated correctly. I am using aftermarket door panels which are junk compared to the originals, however the panel and escutcheon color match was exceptable to me. If you zoom on the other picture, you can see the door panel and escutcheon. I tried to rotate the second picture but had no luck.
Old 04-03-2018, 08:07 PM   #8
med.bronze
med.bronze's Avatar
Where did you purchase the aftermarket parchment escutcheons if you don’t mind my asking?
1971 K-10 Custom
Old 04-03-2018, 10:41 PM   #9
Blazerowner
Blazerowner's Avatar
http://www.lmctruck.com/features/cb/CBDH4.htm
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 04-04-2018, 02:47 PM   #10
SeventyOne
Same. LMC is the only place that has the parchment that i can see. But wonder if it's best to find decent OE ones and paint them...
