Chassis swap
I have a 68 GMC 3/4 ton that I want to switch to a half ton frame. Recently purchased a 71 half ton rolling chassis. What are some differences that I may encounter between the two? They are both long bed wheel base. Any information would be helpful. Thanks
Posted via Mobile Device |
The Older Generation
Re: Chassis swap
Basically the only difference will be the rear cab mounts on the frame. (just use the 1/2 ton body mount cushion set) and the front brake lines from the booster to the frame. (because the '71 frame will have the disk brakes on the front) There will be a few pieces of smaller stuff, like the combination valve on the booster, but just ask questions as you progress on it. LockDoc
Re: Chassis swap
On my ‘68 I bent the original brake lines to the 72 booster/master and run adapters to fit the lines....Incase you don’t have the lines from the chassis. LMK if you need a hand I’m close and would also be interested in the 3/4 T frame if you’re not keeping it.
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback Last edited by projectking; 04-03-2018 at 11:39 PM. |
#4 | |
Re: Chassis swap
Will do thanks!
Scrapper 1
Re: Chassis swap
Was both truck leaf springs or was one coil
Re: Chassis swap
It wouldn't make any difference as long as the whole frame is swapped....
LockDoc
Re: Chassis swap
Would the front cross members interchange so I could keep the body and chassis together? And save myself days of work while still getting the half ton ride and disc brakes? The leaf springs would swap out easily with the axles I am guessing
#12 | |
Re: Chassis swap
Yes, the cross member swap is a bolt in deal.... LockDoc
Re: Chassis swap
Awesome! Should save days worth of work, and give us more driving time.
#15 |
Scrapper 1
Re: Chassis swap
Reason why i ask cus no pics.Now if he had a 3/4 ton with ladder bar and come to like the car riding comfortably there is a big difference My 1965 3/4 ton compared to me 1972 that had leaf springs my 1965 coil springs rode like a car even when it was loaded the leaf spring is a little harsher. But if you never had coil spring you would never know
