03-31-2018, 01:03 PM | #1 |
'66 c10 3 on the tree shifter linkage and carrier bearing bracket
Hey guys, so i'm currently looking for the 3 on the tree shifter linkage rods that go from the end of the column down the transmission forks. Mine were bent and had rust holes in them.
Does any of you have any of these rods for sale? As I understand it, only the rods from '64 to '66 work...am I wrong? I am also looking for the carrier bearing bracket that the bearing for the two piece driveshaft bolts to that is riveted to the frame...mine has been cut out. If any of you have this piece available for sale, please let me know. Let me know what y'all have and I look forward to hearing from ya. -Cam |
03-31-2018, 10:48 PM | #2 |
Re: '66 c10 3 on the tree shifter linkage and carrier bearing bracket
I have a set that I took of my 63 C10 I'm not sure if they would fit.....
03-31-2018, 11:44 PM | #3 |
60-66 Nut
I reproduce the carrier bearing bracket but I am currently out of them. It will be a couple weeks before I would have more laser cut parts for them.
http://www.67-72chevytrucks.com/vboa...d.php?t=620312
04-05-2018, 01:49 AM | #4 |
Sorry for the late reply. Captainfab, those look like great quality bracket and I'd buy one from you if I needed one like that. Unfortunately, the bracket for the carrier bearing is like the one in the attached photo. It's the one that is riveted to the frame that the bearing bolts to. This is the bracket of a friends '64 c10. Does anyone know of a repro bracket or of good one that they would be willing to let go for some money?
Hope you guys are well and thanks for your time. -Cam |
