04-04-2018, 01:34 PM | #1 |
Fuel Tank/Sending Unit Grounding
Just Wondering how you guys went about grounding your behind the Seat fuel Tank and sending Unit. Thank You
Posted via Mobile Device |
04-04-2018, 04:12 PM | #2 |
Re: Fuel Tank/Sending Unit Grounding
The tank is grounded to the body through the mounts and bolts. The sending unit is grounded to the tank through the ring as it touches the tank AND the sending unit.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
04-05-2018, 03:18 AM | #3 |
^^^What he said. If your having issues with your cluster gauge I'd check the ground under your dash and cab to frame ground strap on the passenger side.
1969 Chevy c20(Miss Hackjob) |
