Closed Thread
Old 04-05-2018, 01:14 PM   #6526
RodnRudy
RodnRudy's Avatar
Unhappy Re: What did you do to your truck today? Chapter II
Just got back from a test drive after replacing front coils and shorter rear blocks. Ride quality is better but I don't like the look as much. I'm waiting on new hood hinges so I can throw the hood back on and call it done.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 04-05-2018, 01:43 PM   #6527
Metaldoc
Metaldoc's Avatar
Need a before and after pic of ride height
Metaldoc is offline
Old 04-05-2018, 04:14 PM   #6528
Metaldoc
Metaldoc's Avatar
plumbed in new PCV line, fuel, and vacuum advance. Looks nice and not just hoses. I found that spark plug ends fit perfect on the PCV to 3/8 tubing. I've done a bit of small tubing work.
Metaldoc is offline
Old 04-05-2018, 04:25 PM   #6529
BugzC10
BugzC10's Avatar
Like the clean look!
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 04-05-2018, 04:26 PM   #6530
BugzC10
BugzC10's Avatar
Originally Posted by metaldoc View Post
need a before and after pic of ride height
x2
BugzC10 is offline
Old 04-05-2018, 04:39 PM   #6531
RodnRudy
RodnRudy's Avatar
Her you go:First is before second third after
Phil
RodnRudy is offline
Old 04-05-2018, 04:41 PM   #6532
RodnRudy
RodnRudy's Avatar
MetalDoc excellent job plumbing the fuel and vacuum lines!
Phil
RodnRudy is offline
Old 04-05-2018, 04:58 PM   #6533
Metaldoc
Metaldoc's Avatar
I hate to say it but the lowered look is more my taste. I was going to raise mine back up an inch in the front and 2 in the rear, but now I think I'm only going up an inch in the back, it sits too flat, needs more rake.
I'm thinking about shrink wrap on them to make them black and thanks.
Metaldoc is offline
Old 04-05-2018, 05:00 PM   #6534
BugzC10
BugzC10's Avatar
Slightly higher (almost unnoticeable) in the front, but still looks awesome.
BugzC10 is offline
Old 04-05-2018, 07:35 PM   #6535
jessemthompson
Upgraded the charging system in the truck today. Picked up a full volt and got my wipers to operate normally. Also added brothers trucks fuel fill cover to my cab.
jessemthompson is offline
Old 04-06-2018, 01:00 PM   #6536
stevenfromtexas
stevenfromtexas's Avatar
installed my side and back glass a couple nights ago. waiting on the backorder vent rubber.
Steven
'67 SWB, 250ci, 3OTT.......this is my first build......
I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71"
stevenfromtexas is offline
Old 04-06-2018, 03:23 PM   #6537
Metaldoc
Metaldoc's Avatar
I painted the lines and I like it. I'm waiting for the paint to dry on the new intake bolts to match all black hardware.
Metaldoc is offline
Old 04-06-2018, 03:48 PM   #6538
Jim Boy
Nice touch, I like it, clean and simple. Now when are you firing up the BBQ eh? I have a vision of ribs. Could be wrong but I don't think so.
Jim Boy is offline
Old 04-06-2018, 05:02 PM   #6539
Metaldoc
Metaldoc's Avatar
Thanks man I haven't done any ribs for a while now but will this tide ya over.
Metaldoc is offline
Old 04-06-2018, 06:13 PM   #6540
66clow
66clow's Avatar
New parts! Who doesn't like them? Hope to know how much fuel I have.
66clow is offline
Old 04-06-2018, 06:17 PM   #6541
Jim Boy
Smile Re: What did you do to your truck today? Chapter II
Yuper!!
Jim Boy is offline
Old 04-07-2018, 03:53 PM   #6542
flatbed67
flatbed67's Avatar
I made my windshild washer work.
It turned out to be a lot more work that anticipated, but the cowl really needed a good cleaning out. Now all hoses are new, and the washer works just fine
flatbed67 is offline
Old 04-07-2018, 06:47 PM   #6543
RodnRudy
RodnRudy's Avatar
So I cruised down to my NAPA store this morn and bought a tube of Permatex Gear Oil sealer to fix a nuisance leak on the differential cover. Back home and jacked the old girl up, removed the old cover, cleaned every thing up,stuck a shop towel in the housing to keep the gear lube from seeping out while I applied the sealer and gasket. Applied the sealer to the housing cover and proceeded to install the bolts. I was on the fifth bolt when I realized I forgot to take the shop towel out! I had to remove the cover, gasket and clean up the big mess. I don't have pics cause I had sealer all over everything and couldn't touch my I phone. I'll try again tomorrow after I get more sealer. This could have been a catastrophe if the dim light in my brain hadn't come on. That's what I did to my truck today.
Phil
RodnRudy is offline
Old 04-07-2018, 07:05 PM   #6544
flatbed67
flatbed67's Avatar
Good thing the bulb lit before you went for a drive! It would've been much more work after that.
Anyway:
Work done today, hasn't to be done tomorrow.
I always think that, when getting in from the garage after a partiqularly bad day
Old 04-07-2018, 07:11 PM   #6545
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Went with my neighbor/friend to get a 70 long bed for parts.Borrowed 2 wheel dolly to tow 6 miles. When we got there found the ring gear carrier in bed.Had to put on dolly backwards.Thank good ness no motor or trans so it wasent too bad.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline
Old 04-07-2018, 08:00 PM   #6546
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
Ramp truck got a aux set of batteries installed and charge off the truck battery. I also installed a 3 gallon air tank with compressor for road side assistance if needed.
I think Ill buy a small box to cover the batteries and store some rigging stuff also. I have the tilt column working on it also. I found out today the bowl on the tilt is aluminum . I used plumbers putty to fill up the holes. I'll give it a couple of days to harden and see how it does sanding it.
I came up with a easy way to keep the bowl from moving also. I took the 2 screws that hold the neutral safety switch and placed longer screws in to hold it in place.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 04-07-2018, 09:22 PM   #6547
66clow
66clow's Avatar
Washed it then it rained
66clow is offline
Old 04-07-2018, 09:53 PM   #6548
Metaldoc
Metaldoc's Avatar
Cleaning
Metaldoc is offline
Old 04-08-2018, 11:06 AM   #6549
70 shorty
Where's my beer?
70 shorty's Avatar
Installed new back up lights that have been sitting on the shelf for years. I rarely drive it at night, so it's not been a big issue. Unfortunately the right side is not working, so I need to investigate.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline
Old 04-08-2018, 06:56 PM   #6550
NoStopN
NoStopN's Avatar
I haven't had backup lights on my truck since I bought it. It's not too big of a deal. But, those ditches tend to jump out at me when backing out of the driveway.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Closed Thread
