Saving 1 truck at a time!
Door Hinges
Is it usually the hinge or the pin that wears? I need to replace one and just curious if the kits are worth the effort or should I just buy a new hinge.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
![]() Join Date: Jul 2001
The hinge pins and bushings are what generally need to be replaced. Hinge itself is rather sturdy. When I had mine off I used the glass bead machine at work during lunch to clean them up, prime and repaint. Fairly easy rebuild using a bench vise, hammer and a drift pin. I bought the repair parts from my local truck parts vendor. Re-built all four hinges, upper and lower, driver and passenger side. The upper hinges use a two-part "dentent" plate arrangement to "hold" the door open. They can be persuaded with some judicial use of a pry bar to retain the correct tension. Made a big difference when they went back on the truck. Good luck and Keep On Truckin'
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
most rebuild kits come with oversized bushings and pins.
Thanks...I see how those work now. I checked in LMC and they have them there. I have an old hinge that I will install for the time being. It appears only the bottom hinge is really bad.
