Re: 1970 C20 Manual Transmision Identification Help.
Reason I asked is the bell housing bolts to the crossmember and the crossmember is riveted into place on the frame.
When people swap to an automatic they usually need to remove the crossmember. Take lots of pics. Everybody will jump in and help you out! And welcome to the jungle! |
Ya I will take lots of pics! I was thinking that the original crossmember is prob not there. And I’m assuming that even if the crossmember was takin out and replaced for the 700r4 swap, this can be put back to original? ( if I have the right 4speed tranny).I sure appreciate all the help on this journey to restore this truck! Yes sir, glad I joined! Thank you
I do know that when I put the Bellhousing up to the transmision, the two top horizontal holes lined up but the two horizontal holes on bottom did not. Does this seem normal? And my Bellhousing has two flat spots with a little horn on both sides with vertical holes so it seems to make sense that this is where you would mount the bottom of the Bellhousing to the crossmember. Using the two top horizontal holes and the two vertical holes through the flat spot on the bottom of Bellhousing.
