Old 04-06-2018, 08:44 AM   #1
7tee
7tee's Avatar
Wiper motor problem...
Replaced my wiper motor with a rebuilt one and when I turn them on they will sweep down some on to the cowl every time. Oddly they will park park in the correct position. Are there any adjustments I can do to correct this, thanks Ed...
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 04-06-2018, 08:51 AM   #2
projectking
projectking's Avatar
Re: Wiper motor problem...
Try moving the connector around a bit, I had to open the contacts up some to get a solid connection
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 04-06-2018, 09:46 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
How far up do they park if you adjust them so they only sweep to the bottom of the glass? Mine park about an inch above the edge of the rubber seal.
LockDoc
Leon
Old 04-06-2018, 12:34 PM   #4
7tee
7tee's Avatar
LockDoc
Mine park about 1 1/2" to 2" above rubber but as soon as I turn them on they go down past the rubber and will keep doing it until I turn them off and go back to park... thanks for your reply, Ed
2010 Acura RL...
Old 04-06-2018, 02:57 PM   #5
LockDoc
LockDoc's Avatar
Double check how the arm is attached to the wiper motor under the cowl vent... Here is the instructions on the orientation.
LockDoc
Leon
