04-07-2018, 10:37 PM | #1 |
230 Lower thermostat housing
Anyone making the lower thermostat housing for the 230 6 cylinder? The only one I can find new has the heater hose at an upward angle.
04-08-2018, 01:03 AM | #2 |
Re: 230 Lower thermostat housing
I don't think so, but if the issue is not sealing with the thermostat housing, this stuff will seal anything. You don't even need a gasket.
https://www.summitracing.com/parts/m...SABEgI7KPD_BwE Can't tell you how cool it is to me that some are keeping the 6- banger engines.
Everybody has to believe in something. I believe I'll have another beer. |
04-08-2018, 08:02 AM | #3 |
[QUOTE=shp4man;8232896]I don't think so, but if the issue is not sealing with the thermostat housing, this stuff will seal anything. You don't even need a gasket.
No. It is cracked at the sending unit threads. It's gona need a replacement. |
04-08-2018, 12:57 PM | #4 |
04-08-2018, 02:09 PM | #5 | |
04-08-2018, 03:05 PM | #6 |
Auto Zone web site has some. Maybe something you could use.
04-08-2018, 07:49 PM | #7 |
Look in the for sale section here. Better yet just become a supporting member and post a wanted ad.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-08-2018, 07:57 PM | #8 |
I've looked in the parts for sale section but didn't see anything. I also did a search on that section but no luck, yet
04-08-2018, 08:11 PM | #9 |
So has anyone used the Lower Thermostat Housing with the angled heater hose outlet? Does it cause any problems?
04-08-2018, 11:58 PM | #10 |
60-66 Nut
I might have what you need. Let me look at the shop tomorrow.
04-09-2018, 02:39 PM | #11 |
It looks like we were able to weld up the crack. It's holding for now.
CaptianFab, If I have any more leaks I may PM you. Thanks for the responses. |
