Old 04-12-2018, 05:06 PM   #1
brandon325
68 C10 Rearend Hitting Wood Bed
I was hoping someone could help me understand why my rearend is hitting the under side of my wood bed. Here's some details of my configuration.
1968 Chevy C10 SWB
2 in lowering blocks
Stock trailing arms
air bags in rear
c-notch
CPP shock relocators
20 in wheels
The issue is not with the tires rubbing or anything like that. I'm starting to install the new wood bed and in the process I found out that when the air is out of the bags and it sits on the 1/2 inch bump stop (provided in cnotch kit from CPP) the rearend is about 2 inches past where the bed is suppose to be. See pics. I know I could put a 2 inch bump stop but that kinda defeats the whole purpose of having the c-notch. I would have to inflate the bag so much the ride would be super stiff and zero travel into the c-notch. Would the tubed trailing arms help? I know the geometry is different, I just don't know if its going to help? Also, would removing the 2 inch blocks help much. I really don't want to raise the truck back up. Any suggestions?
brandon325 is offline   Reply With Quote
Old 04-12-2018, 06:20 PM   #2
SCOTI
SCOTI's Avatar
Re: 68 C10 Rearend Hitting Wood Bed
Very common. The rear pumpkin will contact the floor once the truck is dropped far enough. Go w/some taller bump-stops or raise the floor.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-12-2018, 09:09 PM   #3
mongocanfly
mongocanfly's Avatar
(2 in lowering blocks Stock trailing arms air bags in rear c-notch)
^^^this^^^.....like said..most raise the bed floor.....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-12-2018, 11:25 PM   #4
brandon325
Thanks for the feedback. Any good sources on how to raise the bed without damaging my new paint job. Obviously, I didn't think it through.
Old 04-13-2018, 09:42 AM   #5
SCOTI
SCOTI's Avatar
Easiest way is a 2nd/top faux floor. Install the regular floor that positions the bed/body relative to the frame but that's cut-out for clearance over the rear end. Add spacers the required height on top of that & do a 2nd floor on top. Their will be additional weight but it can be minimized using lighter weight materials.
Something like this.....
http://www.horkeyswoodandparts.com/page2.php
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-13-2018, 10:12 AM   #6
68is4me
68is4me's Avatar
I am in the same situation. I am just going to cut the boards out to allow the pumkin to sit lower. Then I will hopefully make a small hump out of metal to cover it up. I don't have it all figured out yet but I don't want to raise the bed floor.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 04-13-2018, 10:55 AM   #7
SCOTI
SCOTI's Avatar
Lots of guys do it this way as well.
On my 67, I raised the original steel floor up 4" & stepped the area above the housing up another 4". On my CC dually, I used the OE front rear floor sections to position the bed, added spacers, & a 2nd floor on top. On my 64, I'll be raising the floor 6".
I prefer the flat floor for trucks that still get used as a truck. It's much easier for loading/unloading heavy stuff.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-18-2018, 07:09 PM   #8
DLW
My PB notches came with a 1.5" bump stop, and aired out I have about 1/8-3/16" before hitting the bed floor, so pretty much the same situation as you. Would love to get another inch drop back there, but really hate to cut the bed floor up to achieve it, but am thinking about it.
DLW is offline   Reply With Quote
Old 04-19-2018, 11:27 AM   #9
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Not sure why this is surprising. GM designed the truck to have diff clearance when it gets no lower than factory max compression. If you notch the frame, you are changing the max compression and then run into bed floor clearance. Yeah..... GM didn't design these for notching the frame.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-22-2018, 12:06 AM   #10
60apache
60apache's Avatar
here is what I did
60apache is offline   Reply With Quote
