Correct engine?
I just bought a 1963 K10 long bed and I am trying to find out if it's got the correct engine.
The engine numbers don't match the VIN number. It's a 230 six . Is there any way to verify its the engine it came with by the VIN or on the vehicle. I am thinking of putting in a 283 v8. The six is very lacking in power! And will a small block drop right in? Thanks. |
#2 | |
![]() Join Date: Sep 2006
Re: Correct engine?
I see you are in SF also, if you need any advice let me know, I am happy to help.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
![]() Join Date: Aug 2013
Re: Correct engine?
One way to tell if 6cyl only came with manual? Or did they call me with autos? The reason I say that cuz my 65 had a 283 with powerglide. The frame has the auto bracket vs the manual bracket. So if 6cyl only came with manuals then u can narrow it down to only 6cyl vs V8, that won’t tell which 6cyl thou.
#4 | |
![]() ![]() Join Date: Apr 2012
Re: Correct engine?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
1962 C-10
Re: Correct engine?
I remember reading somewhere that in 1963 the 4x4s still had the old 235s in them.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
Re: Correct engine?
I checked the casting numbers on block and it is definitely a 230 six.
Looks like it's time for an upgrade. Thanks for the Info. |
