Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-15-2018, 02:57 PM   #11
Shotgunn
Shotgunn's Avatar
Re: 67-72 Chevy Truck fuel gauge diagnostics 101
I may need therapy before this task is accomplished...
Gauge is at 3 o'clock position..
new tank/sending unit/ wires go all they way into the cab..proper ground.(LMC under bed tank)
pull the brown wire clip out of the fuse block and it reads 92 ohms with a full tank of gas. plug the clip back into the fuse block an check it while plugged in..32 ohms..back feed? I have 12.6 volts at the #3 on the plug with the key on. the battery and temperature gauge is disconnected. after market gauges installed oil/volts/temp.
Shotgunn is offline
