Old 04-14-2018, 01:38 PM   #1
Clyde65
Clyde65's Avatar
6l80 questions
Is there any difference between a 2013 and a 2015 6l80?
Found out my trans is a 2013, tuner says the pcm/motor is 2015 and won’t talk to the older trans, is this correct??
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-16-2018, 10:29 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: 6l80 questions
Quite possible. The tuner should b able to do a segment change within the tune to make it work.
Hart_Rod is offline   Reply With Quote
Old 04-16-2018, 01:27 PM   #3
Clyde65
Clyde65's Avatar
Re: 6l80 questions
I’m being told that it needs a flash to get the two systems to talk, idk, paid one guy to do it and he leaves to get a “GM” scanner and then calls me with, mine won’t work on your issue....I’m looking for that jerk now...
Clyde65
Rebuild of Clyde
support our troops!
Old 04-16-2018, 07:27 PM   #4
Goats86
Re: 6l80 questions
Check with Brendan at lt1swap.com. He seems to be very knowledgeable.
Goats86 is offline   Reply With Quote
Old 04-16-2018, 07:34 PM   #5
Clyde65
Clyde65's Avatar
Re: 6l80 questions
Clyde65
Rebuild of Clyde
support our troops!
Old 04-17-2018, 09:02 AM   #6
Overdriven
Re: 6l80 questions
Definitely do some research at LT1swap, as Goats86 said, have a look at HPTuners forums too. I’m not an expert by any means but the tuner should be able to do a segment swap in HPTuners or just flash the ecu to a 2013 operating system if your engine was also available in 2013. Both are a little more complicated than a “standard tune” and not all tuners may be experienced with the process so be sure to ask your tuner questions.
Overdriven is offline   Reply With Quote
Old 05-13-2018, 09:47 PM   #7
vannatta20
vannatta20's Avatar
Re: 6l80 questions
The ECU and tcm need to have matching operating systems. The best way to do this is with gm tis reprogramming service. Hptuners can do a full tcm flash as well but you need the right operating systems. I can help if you haven't resolved the issue yet.
vannatta20 is offline   Reply With Quote
