04-10-2018, 10:12 AM | #1 |
6-lug to 5-lug swap on a 67 C10
This may be a repeat of questions already on the site. If someone has a link to a forum already addressing this, please let me know. Would like input for a donor vehicle I can find that will provide direct front K-member and rear end for a 6 to 5-lug swap. Easy with no major mods is what I am looking for. I want front disc and rear drum with 5-lug. Plan on looking for a donor pickup for the parts. What am I looking for? I figured 71-72 would work, but I have heard newer years in the C10's would also work. I already have power brakes and figured by utilizing equalizer valve on donor vehicle I could also retain the dual cylinder power brake unit already on the truck. And yes it is a Chevrolet with rear coil spring set up. What do you say? Thanks in advance...
choctawchevyclassics Last edited by choctawchevyclassics; 04-10-2018 at 11:14 AM. Reason: more info |
04-10-2018, 12:54 PM | #2 |
Re: 6-lug to 5-lug swap on a 67 C10
The above link should help out. 71-72 crossmember is an obvious choice but 73-87 crossmembers are also a direct bolt in. Whatever you choose pay attention to the inner and outer tie rod ends as they were different lengths through the years, and ball joints are year specific to the spindle used, this is where the link above will help out. I’m in the same boat with a 67 and wanting to go 5 lug as well, mostly for easy rotor replacement. Local parts stores aren’t going to have 6 lug rotors and disc conversion kits don’t tell you what components they use so I’m going to assemble my own so I know what the components are. I’m just going to swap to disc spindles, use the appropriate balljoints and tie rods. For the rear new axles for my current rear end and new drums. I don’t trust the manual master and lines in the truck so all that is going and being converted to power brakes anyway. Last edited by Overdriven; 04-10-2018 at 01:03 PM. |
04-10-2018, 01:09 PM | #3 |
Why not just do a disc brake conversion and some new axles? Unless your truck is hammered with rust, I don't see the point to swapping the entire front cross member just for the disc brakes when a simple swap kit or new ball joints (which I imagine you would replace anyways) to put the 71/72 spindles on, would do.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
04-10-2018, 01:21 PM | #4 | ||
"I ain't nobody, dork."
I agree with demian. I swapped everything from a 1972 C15 over to a 1969 C10 frame. Upper and Lower Control Arms (when actually you only need the lowers), spindles, rotors, calipers and the steering linkage. Tie rods are a different size so I snagged all the steering stuff too. Then put new 1972 Ball joints abd new upper and lower control arm shafts in. All made by Moog.
For the rear end I just bought 5 lug conversion axles made by Moser and slid them in to the 1969 housing. I left the front 1969 crossmember in place and never touched it. One thing to note. Front drum brake rigs have steel brake lines that terminate at the rear of the crossmsmber before going in to the flexible rubber lines. Front Disc brake rigs have steel brake lines that terminate at the front of the crossmsmber before going in to the flexible rubber lines. A 67-70 drum brake front will not have the tabs on the crossmember for the steel brake lines to mate to the flexible rubber lines. So you'll need to weld on new tabs and run new front steel and rubber brake lines. Or you'll be forced to run a rediculously long flexible rubber hose to the caliper. You can see how I did it in my "Rebuild of Creeping Death" build thread. Link is in my signature line. Gary
04-10-2018, 01:23 PM | #5 | |
Ill post up some pics when Im done.
04-13-2018, 01:20 PM | #6 | ||
71-72 trucks have the caliper towards the rear as well. But the brake lines come from the front. The soft line attaches towards the front of the caliper.
I used stock 1972 brake lines and calipers for my build. So I ran the lines exaclty how they came from the factory in 1972. Gary
04-13-2018, 01:55 PM | #7 |
I have a 70 c10 and I had the same problem you have now. I went the route that your thinking with donor parts from another newer truck.
After finding all of the parts and installing them what I realized was that for the time, effort, and money it wasn't worth it. Because at the end of the day you still had old 40 year old parts on your truck, and for a few bucks more you could buy complete conversion kits for both the front and back ends! I end up replacing all of the major components a few years later that I installed! The conversion kits provide better handling and braking that a newer truck just can't offer.
Brian Ritter |
04-14-2018, 11:40 AM | #8 |
I've never heard of doing frame alterations to do disc brake/5 lug conversion. When I put discs and converted to 5-lugs on my 69 I swapped on the front suspension and steering from a 71 and used a 71 rear axle with 5-lug axles.
What, exactly, is different about the drum brake frames and disc brake frames and why would making such a frame change be required or desired?
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
04-16-2018, 08:03 AM | #9 | |
I already bought a complete K-member this past week for $50. I would say a pretty good investment. I have owned several of these pickups and never had a single problem with the factory disc brakes or the front suspension and steering. Spend thousands on the aftermarket stuff if you want. I am building a daily driver and that's what it will be for a fraction of aftermarket...
choctawchevyclassics |
04-16-2018, 08:55 AM | #10 |
If you got a factory 5 lug disk crossmember setup with all the goodies for $50, you got a nice deal. And deals like this, and bone stock factory replacement components, are some of the main reasons the crossmember swap is more popular than an aftermarket swap. All comes down to whether one can find a suitable crossmember donor. Aftermarket is a fine way to go too, but can end up being more pricey, especially if one is finding crossmembers for $50. Good on ya!
04-16-2018, 09:06 AM | #11 |
Isn't the k-member you speak of part of the frame? More specifically then, what is the difference between a drum k-member and a disc k-member?
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings Last edited by Rich69shortfleet; 04-16-2018 at 09:54 AM. |
04-16-2018, 09:15 AM | #12 |
There is no difference between the two! You can mount a drum and disc brake setup on both of them! If you like old factory brake and suspension setups then go right ahead, I like to improve my trucks so I can drive them how ever I want not just baby them!
Brian Ritter |
04-16-2018, 02:59 PM | #13 |
I have a 67 K-member with drum brakes. The replacement K-member I bought is already set up with everything for the disc brakes. K-members are pretty much an unbolt the old and bolt up the new. Other than changing out brake lines and hooking up the steering.
