72 c10 easy tranny swap
Ok so I have searched the forum a good bit. And I guess I need more info than what I’m finding. Got a sag 3sp. Shifter in the floor. Still mechanical. Looking for the easiest 5 spd tranny to swap on a 307. T5 is tossed out. Was looking at the 4500 or the tremec 600. I’m starting to put more into this than planned like a very project that I or anyone has done. So the 4500 looks like I’ll need to relocate the shifter or go with a hurst shifter conversion? Correct? The tremec 600 will need a new bell housing? Which one is the most straight forward swap? What else would be to do this swap? Did I miss a tranny that would be easier to swap in?
Re: 72 c10 easy tranny swap
If your truck has a rear end ratio on the faster side of the spectrum a 5-speed may be of little benefit...
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
Why not a T-5?
Those other transmissions are overkill with a 307
![]() Join Date: Oct 2009
I wouldn't rely on "was told" rear gears when deciding on a trans swap.
What are the details of your truck, besides 307 and 3-spd manual? (year, VIN first 3 characters, C10? C20?) Better yet, if your truck has a SPID, just post that, it will help us figure all of the above. A 307 in it now may not necessarily mean it was born that way. Do you still have the boss on the steering column for the column shifter? Is there any annotation on your SPID for a gear ratio (again, or just post it)? All of the above can only narrow down what it was born with, not necessarily what it has today. It's at least been modified to have a 3-speed floor shifter which was not a factory option, so who knows. What's the reason you want to switch to a 5-speed? Reduced highway rpm? To Alex's point, if you happen to have a 3.07 rear, for instance, the overdrive ratio won't be such a good thing at higher highway speeds, rpm will be too low. Bottom line, it's worth doing some of the rear gear checks, either by tire vs d/s rotations vs # wheels turning, etc to ballpark it (several threads on here about that) or, better yet, popping the rear cover (rear end dependent) and counting teeth just to be sure - then you can make a more educated decision on how to achieve your goal. If you're certain the truck has full original driveline, then we can help you figure out what it came with and you can go from there. Also keep in mind that the only accurate way to figure out what your rpm at a given speed is on these old truck when you don't know if they've been modified is with a GPS and tach while you're driving it. If changes were indeed made to the rear, then speedo would be completely inaccurate. FWIW, a T5 is just fine for a 307 engine, unless you plan to do a bunch o burnouts. A Tremec 600 is a bit pricey to be hangin out behind a 307, unless you plan a future engine swap, etc. All comes down to how you're gonna drive it. |
![]() Join Date: Feb 2016
How about one of the Ranger hi/low's? Make your 3 speed into a 6 speed.
http://www.advanceadapters.com/categ...lete-units/91/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
not on your list but muncie 4 speed easiest....same length, same spline on both ends, same floorshift hole
1970 short step c10 leaf spring 454 |
#8 | |
After removing the cover you count the teeth on the ring gear and the pinon gear then divide them to get the ratio. Many times you can find the numbers stamped on one of the gears. 3:73 should be 41 teeth on the ring and 11 on the pinon. 11/41=3.727272 or 3:73. The stampings may look look like (41*11 or 11-41). Here is a link with common ratios.
http://www.crawlpedia.com/gear_tooth_calculator.htm
So tranny shop here in SC recommended the nv3500. Anyone running one?
Here is a link to Novac's tranny information site. Just click the 5 speed bar. Gives dimensions, ratings, ratios and lots more. Hope this helps.
https://www.novak-adapt.com/knowledg...ssions/manual/
