Old 04-14-2018, 09:53 AM   #1
Those who have done MileMarker conversion...
Are you happy with the results, cost and reliability? Thinking of doing the 502 kit in my 87 half ton. No garage up here in Maine but I have a driveway and I’m not afraid to use it
https://milemarker.com/product/502-conversion-kit/
Old 04-14-2018, 11:36 AM   #2
B. W.
B. W.'s Avatar
Re: Those who have done MileMarker conversion...
I worked for a company that had a fleet of GM trucks in the 70's & 80's. We converted every 203 we had. I can't remember ever having an issue with them. I believe they picked up fuel mileage but can't remember that either! (but what would that be? From 8 mpg to 10?) The trucks were loaded heavy & run hard. I don't remember the name of the conversion kits but they were similar in design.
With that said, my DD is a 79 GMC K25. It still as the full time slugs in the axle but someone converted the T-case. (I'm guessing the PO took the lockout hubs with him) It has slop in the case when engaging 4wd & has gotten worse over the years. It's so bad now that I need to repair or replace it. This truck has been worked hard plowing & hauling cord wood.
B. W. is offline   Reply With Quote
Old 04-15-2018, 10:03 AM   #3
v30crewcab
v30crewcab's Avatar
87 wont have a 203 tcase. it should be a 208. all you need is manual hubs to get rid of your auto hubs in that case.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-15-2018, 05:35 PM   #4
Thanks! I’ll crawl under and look...after the snow melts.
Old 04-18-2018, 04:11 PM   #5
I have the 208 transfer case, Mile Marker does not make a conversion kit for this tcase. I can put manual hubs on it but the front shaft is still going to turn. (As per the tech at mile marker)
Old 04-18-2018, 07:07 PM   #6
GSP7
GSP7's Avatar
No ,,,, Hubs unlocked, 208 in 2 wd, not 4wd, the front drive shaft will not spine when you are driving....... Tech at milemarker is a Idiot
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 04-19-2018, 08:17 AM   #7
Thanks, think I’ll just order mile marker hubs with the bolt kit (comments ?).
104 hubs with 1/2 ton nut conversation kit. $113.35
https://milemarker.com/product/104-hubs/
This truck stays in Maine and only driven in summer, not really a wheeler.
Old 04-20-2018, 07:23 PM   #8
86454k30
86454k30's Avatar
You don't need the nut kit either. Your hubs are auto locking not full time so unless they are bad they are fine.
86454k30 is offline   Reply With Quote
Old 04-21-2018, 10:19 AM   #9
Just like school, I was never a good student but always eager to learn. Y’all are the teacher.
Thanks!
