New battery, but won’t start unless on a jumper box
Help me out here guys. Truck barely turns over like battery is low so since the battery was actually 10 yrs old, I replaced it, figuring that was the issue. As early thing with the brand new battery. Turns over very slowly but if I hook up my jumper box, it starts right up. Checked battery with a multimeter & it shows good, alternator is putting out/ charging fine & I have cleaned/ tightened/ checked the terminals & ground connection on the cables.
Truck was stored at a friends house for 6 months while I was moving & after jumping it off initially, did fine on the 275 mi trip over a couple weeks ago. Any ideas on what to check/ test next? Thanks!
I called my stockbroker last week and asked him what I should be buying .......... he said "Canned Goods and Ammunition". ![]() |
![]() Join Date: May 2010
Re: New battery, but won’t start unless on a jumper box
How are you hooking up the jumper box? To plus and minus battery terminals or plus terminal and engine ground?
New batteries can be bad.....
Need to take new battery to parts store, have them load test it, that will tell you.... |
Hooked it up both leads to the terminals.
#5 | |
May swap in another battery that I know is good first. Where I just moved to in the men’s is about a 35 mi round trip!
Just went out & swapped the battery from the 69 Mustang over & it started right up. Must be a load issue with the new battery as voltage shows fine with no load on it.
Thanks guys!
Roadtrip!
![]() Join Date: Feb 2003
Have seen it before.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
it's probably your starter is it a stock one
Interested in what you all suggest in regards to replacement starter options
71 C-20 07 Magnum RT AWD |
Bad cell
Stan 67 swb BLU MULE posted via flip-fone |
Sounds like a duralast battery. They don't last and have problems.
Interstate batteries worth the few extra bucks. Get it load tested as mentioned here. Or just push for another one Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
