04-21-2018, 03:28 PM | #1 |
Proper way to cutout metal dash face to be reused
I know it unbolts and to cut the slotted area but whats the best way to cut the corners,by the end of dash pad?
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
04-21-2018, 07:54 PM | #2 |
Re: Proper way to cutout metal dash face to be reused
I would like to hear what others have to say on this also
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
04-21-2018, 08:38 PM | #3 |
This is how i did my repair to the radio hole
Most of the weld seams i hid, but i did have to metal finish underneath across the bottom. No filler, and used some blend solvent in my single stage Centari. Turned out good, most of the welds are hidden under the dashpad |
04-21-2018, 08:47 PM | #4 |
That looks like a nice job on the radio fix, bur I believe the op is talkin about the whole dash.
04-21-2018, 09:12 PM | #5 |
The best way is to not cut anything. Unbolt it, pull the windshield and remove the spotwelds along the windshield seam. I think it’s actually less work to remove and put it in that way.
04-21-2018, 11:29 PM | #6 |
Agreed, drilling out factory spotwelds is alot better and easier than cutting and then trying to weld back together.
04-22-2018, 12:05 AM | #7 |
whats the easiet way to drill out rivets?
04-22-2018, 08:17 AM | #8 |
Look up Roto-Broach cutters.Well worth the money.You can buy cheap spot weld cutters,but you just get cheap cutters.
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
04-22-2018, 11:17 AM | #9 |
yea i have one of those, just making sure i`m doing it the easiest, cleanest way, and i don`t want to screw up the lower windshield lip, as this is a super nice dash i`m removing. thanks
