Old 04-22-2018, 04:47 PM   #1
WannaBe68
WannaBe68's Avatar
Any Idea How To Remove these?
I've been banging away at these little clips for the lower 4 panel screws with no luck. The skin even started getting pushed in a bit. And yes - I've soaked them with all kinds-of of break free stuff!
Any idea how to remove these things?
Thanks!
WannaBe68 is offline   Reply With Quote
Old 04-22-2018, 05:35 PM   #2
HO455
HO455's Avatar
Re: Any Idea How To Remove these?
The doors of my 67 had this style of cage nuts in them. You might try looking at the backside with a mirror,. Who know what someone may have done it the past.
RIP Bob Parks.
Old 04-22-2018, 06:08 PM   #3
WannaBe68
WannaBe68's Avatar
In the top left picture - the arm rest mounting holes have those exact kind-of cage nuts. But these panel nuts look the same on the front side and backside. Almost like they were pressed in??
Old 04-22-2018, 09:18 PM   #4
HO455
HO455's Avatar
Are they stripped? If so maybe drilling and tapping them one size larger in place is the answer.
RIP Bob Parks.
Old 04-22-2018, 09:37 PM   #5
WannaBe68
WannaBe68's Avatar
Some have the screw broken off, but I have all new hardware including the cage nuts you showed. I sure would like to remove these and start over...
Old 04-22-2018, 10:34 PM   #6
franken
They're welded on.
Old 04-22-2018, 11:08 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
What he said.
Some are cage nuts some are welded. Looks like yours are welded. The cage nuts would be loose in the hole and you just squeeze the spring sides in to remove them.
LockDoc
Leon
Old 04-23-2018, 10:06 PM   #8
vectorit
What?
vectorit's Avatar
Welded to the panel
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-23-2018, 10:58 PM   #9
WannaBe68
WannaBe68's Avatar
Sorry about the focus - but the backside looks as square as the front side. I don't see any kind-of "welds"... Could they be pressed in? You guys know these ol' vehicles, so I'm sure I'm missing something!
Either way they have been playing havoc with me!
Thanks again for chiming in.
Old 04-23-2018, 11:04 PM   #10
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
A couple of mine came loose removing the screws so I think a quick tap with a hammer and punch would do the trick...
68SWB4x4 is offline   Reply With Quote
Old 04-23-2018, 11:19 PM   #11
vectorit
What?
vectorit's Avatar
I think they are squished in, and then electrically welded.
When you get one that falls out, it looks like a simple square nut that has been squished. At least the ones in my looked that way.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 04-23-2018, 11:51 PM   #12
HO455
HO455's Avatar
You might try lightly grinding them with a small disc grinder until they are flush and try tapping them again. The smaller the disc the deeper into the nut you can get without hitting the panel. You might tape some shim stock around the nut to give the panel some protection as you go at it. Might work. Either that center punch them and drill and tap.
RIP Bob Parks.
Old 04-24-2018, 10:44 AM   #13
WannaBe68
WannaBe68's Avatar
I've been laying into them with a hammer and punch - so far it's been a big fat No-Go! Those badboys are "squished" in there nice and tight.
I'll break out the Dremel and a smallish cut off wheel and see what I can do.
Thanks again!
P.S. For basically a rust free Burb, that pic of the inside of the door makes it look nasty in there... might have to paint some POR15 in there before sending it out for paint...
Old 05-07-2018, 10:02 AM   #14
WannaBe68
WannaBe68's Avatar
Since you are sitting on the edge of your seat waiting to see how this turned out -
I bought a drill and tap combo for the size of screw that goes into these nuts. Drilled out the broken off shafts stuck in the nuts and then taped the holes and then ran the tap through all of the holes. Some things you slap your forehead about and this was one of them!
W-A-Y easier than hammer and chisel or dremel and cutoff wheel. Way easier...
Old 05-07-2018, 10:09 AM   #15
LockDoc
LockDoc's Avatar
Good deal, glad you got the problem resolved. I have done it both ways. The ones that break out I have replaced with the plastic inserts for license plate screws. That also worked good.
LockDoc
Leon
Old 05-07-2018, 09:32 PM   #16
HO455
HO455's Avatar
Excellent!! Now it's party time!!!
RIP Bob Parks.
