Old 04-24-2018, 07:35 AM   #1
dbaillargeon
Headlight upgrade
Hello all,
I have found this site a wealth of knowledge over the past few years. I wanted to thank everyone for that.
My predicament now is headlights. I have two with bulbs that need to be replaced so I decided now is a good time to upgrade. I would like to upgrade my original 1969 GMC C30 headlights to LED. They are the 4 5.75 bulbs. I have no idea where to start or the best bulbs for the job.
Any and all information would be welcome!
A lot to think about, not much to worry about...
dbaillargeon is offline   Reply With Quote
Old 04-24-2018, 07:44 AM   #2
1968 baby blue C10
1968 baby blue C10's Avatar
Re: Headlight upgrade
So do you currently have the factory seal beams or have they already been converted to halogen?
68 C10 long-fleet, Long and low is the way to go. factory: 307 sbc, SM465 4-speed, 12 bolt 4.11 rear end. 75,000 original miles.
Build:Ole Blue
Millennial and can drive stick.
"Too many people have opinions on things they know nothing about. And the more ignorant they are, the more opinions they have." -Thomas Hildern
1968 baby blue C10 is offline   Reply With Quote
Old 04-24-2018, 08:24 AM   #3
Mike C
Mike C's Avatar
The Nokya sealed beam conversion kit and LASFIT 9005 HB3 9006 HB4 bulbs seems the way to go. The lights are $90 a pair on Amazon and the bulbs are $63 for all 4.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-24-2018, 09:53 AM   #4
dbaillargeon
All sealed beam..still original.
Old 04-24-2018, 09:59 AM   #5
1968 baby blue C10
Okay, so are you wanting a halogen conversion with LED headlight bulbs, or the fancy projectors or whatever with the LED halos? Just trying to clarify.
Build:Ole Blue
Old 04-24-2018, 10:01 AM   #6
dbaillargeon
100% correct
Old 04-24-2018, 10:05 AM   #7
1968 baby blue C10
100% correct
Wait I think you misread my question. So, a factory looking housing with a LED bulb? OR something like this?:
Build:Ole Blue
Old 04-24-2018, 10:30 AM   #8
dbaillargeon
I don't have a preference yet...looking for ideas. Would like plug and play but wouldn't be opposed upgrade of the whip as well
Old 04-24-2018, 10:35 AM   #9
1968 baby blue C10
Oh okay. LMC has a pretty good selection of traditional lights and traditional looking with halos. These are pretty cool but pricey:
Build:Ole Blue
Old 04-24-2018, 02:30 PM   #10
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Headlight upgrade
Before you do the lights do the relay upgrade this will insure you get the most out of your lights to begin with. A lot of people stop at this mod after seeing how bright they are.
I have been looking at a set for my 64 SS Impala as well but haven't found what I want yet.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-24-2018, 02:35 PM   #11
1968 baby blue C10
Not trying to hijack the thread but what is this upgrade? Is it a plug and play deal?
Build:Ole Blue
Old 04-24-2018, 04:39 PM   #12
Andy4639
Old member
Andy4639's Avatar
It depends on if you buy a kit are make your own. I made my own and wired them in. The relay takes the load off the truck wiring system. It improves the out put of your lights.
Old 04-24-2018, 04:57 PM   #13
panhead59
Please don't buy the "new" ultra bright ones ! Don 't know what kind they are but they are blinding for the oncoming traffic. I drive a tractor trailer rig at night and my colleagues and I all agree they should be illegal ! The shade of white is just very uncomfortable to the eye. I wouldn't want to be on a country road with those lights coming at me ! They absolutely blind you !
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom)
1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK.
1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive !
panhead59 is offline   Reply With Quote
Old 04-24-2018, 08:09 PM   #14
AJC
As I have never had a gmc. Do both bulbs act as hi/low or dose it just switch from inner to outer or vice versa?
AJC
AJC is offline   Reply With Quote
Old 04-24-2018, 08:33 PM   #15
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The outer lamps are both high and low beam. The inner lamps are high beam only.
So on high beams, all four lamps are lit.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 04-24-2018, 11:26 PM   #16
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
A slight diversion in the topic, but maybe it will help the OP. Does anyone have a before/after pic of the difference in headlight brightness with a relay kit? I suspect that a relay kit would also serve to brighten the tail and marker lights, since their voltage supply would be higher if the headlights were fed through a circuit directly from the battery, instead of all the power going through the headlight switch. I could just drop the $30 for the relay kit, but I would rather spend $30 worth of time on diagnosis, because I was so poor as a kid that the only thing I could pay was attention.
~Steven
Simi Valley, CA
Old 04-25-2018, 02:40 AM   #17
EVRLET
EVRLET's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=761605
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 04-25-2018, 12:01 PM   #18
Steeveedee
Steeveedee's Avatar
Originally Posted by EVRLET View Post
Thanks, but I'm curious about just the relay and stock bulbs difference first. I like what you did there!
~Steven
Simi Valley, CA
Old 04-25-2018, 12:13 PM   #19
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I bought a set of the LMC bulbs like up above. I also bought their relay wiring harness in hopes of making them brighter. The wiring harness didn't last 2 months. Relays immediately gave up.
I already had some HID lamps installed, not the old style bulbs. Once I get the other issues worked out on the pickup I intend to install the new LMC bulbs and try to get the harness working again.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 04-25-2018, 01:35 PM   #20
Andy4639
Old member
Andy4639's Avatar
This is why I made my own harness and it works great. I've done my 71,67, 64 Impala and my 56 Bel Air + a few friends vehicles.
Old 04-25-2018, 01:43 PM   #21
red71cheyenne
Back in the sticks
What did you do differently in making your own harness? i.e. beefier relays?
Thanks,
Jeff
2011 K1500 Suburban
2014 K1500 Pickup
Old 04-25-2018, 02:22 PM   #22
EVRLET
EVRLET's Avatar
There is a huge difference in cheap relays vs Bosch-Tyco relays. The longevity of the Bosch is amazing. I ordered some cheap relays for my cooling fan and air ride management, but the relays failed within a month. I paid extra for the Bosch brand and a year later, still going good. The relays in my Ford Expedition are all Bosch and I have never replaced one...bought new in 2000 and has 180,000 miles. That says something.
Old 04-25-2018, 03:00 PM   #23
Andy4639
Old member
Andy4639's Avatar
Talking Re: Headlight upgrade
Thanks,
Jeff
When I did mine LMC was having terrible reviews on theirs. The wires where backwards. Also as stated I used Bosch relays. Mine have been in the truck for several years now and no problems.
Old 04-25-2018, 09:44 PM   #24
BCOWANWHEELS
I just bought a pair of 7 in halogens from rockauto for 8.00 each
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 04-26-2018, 11:15 AM   #25
red71cheyenne
Back in the sticks
Thanks, when I reinstall, I'll upgrade to Bosch relays and check the wiring. That could have been the problem all along, I just don't drive it enough.
2011 K1500 Suburban
2014 K1500 Pickup
headlights, lights, upgrade led
