Old 04-26-2018, 01:42 PM   #5
HO455
HO455's Avatar
Re: So, what should I do from here?
Heater cable lubing as previously recommended, inspect the heater switch, the heater resistor, the cigarette lighter wiring and the ignition switch wiring. They may have been over heated at some time in the past. I would also do a careful inspection of the bottom of cowl for rust and touch up the paint if it is failing.
P.S. if you have access to the dimmer switch its wiring is another problem area worth looking at.
RIP Bob Parks.
